Changing the Speed of a Simulation
Revision as of 09:59, 21 May 2013 by ReeceL (talk | contribs) (ReeceL moved page Changing the speed of a simulation to Changing The Speed Of A Simulation without leaving a redirect)
File:Project Options General Options.png
Clock speed
Select the Clock Speed option from the Build -> Project Options menu to change the speed of the simulation. Simulation speeds can vary from 0.25 Hz (or one simulation every 4 seconds) to 1000Hz (or one simulation every 0.001 seconds).
Simulation speed
In addition, you can ask Flowcode to simulate the flowchart as fast as possible. When this happens, Flowcode does not update the variables, call stack and microcontroller views whilst it is running but any external component views do get updated.
Configuration information
Select 'Configure' from within the Build > Project Options menu to open the chip download configuration window. A number of options are available that allow you to change download parameters. For details on the various options see Configuring the chip.
