Component: Actuators (BL0127) (E-blocks 2)
Revision as of 12:09, 6 April 2023 by MartinW (talk | contribs) (→Examples)
Category E-blocks 2
Actuators component
The Actuators board allows for investigation into several different motor types. Included on the board is a DC motor with both analogue and digital feedback, a servo motor and a stepper motor plus the circuitry to drive the motors.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Demo program using the Eblocks 2 Actuators Board BL0127 connected to BL0011 PIC programmer BL0127 Actuators Demo for PIC
DCMotor_Break
DCMotor_Break
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
DCMotor_Coast
DCMotor_Coast
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
DCMotor_DC_Feedback
DCMotor_DC_Feedback
DCMotor_DC_FeedbackSim
DCMotor_Disable
DCMotor_Disable
Disable the motor output
DCMotor_Enable
DCMotor_Enable
Enables the motor output
DCMotor_Forwards
DCMotor_Forwards
Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property.
- UINT Duty
Sets the motor power for PWM or H-Bridge outputs
DCMotor_Reverse
DCMotor_Reverse
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
- UINT Duty
Servo_AutoMoveToPosition
Automatically moves towards the new position at a fixed rate determined by the AutoMoveSpeed.
- BYTE Channel
The channel to assign the new position. Range: 0-7
- BYTE Position
Position to automatically move to. Range: 0-255
Servo_AutoMoveToPositionInt
Automatically moves towards the new 16-bit position at a fixed rate determined by the AutoMoveSpeed.
- BYTE Channel
- UINT Position
Position to automatically move to. Range: 0-65535
Servo_DisableServo
Servo_DisableServo
Disables a servo channel effectivly disabling the motor.
- BYTE Channel
The channel to set the position for. First channel is zero.
Servo_EnableServo
Servo_EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
- BYTE Channel
Servo_Initialise
Servo_Initialise
Sets up the servo motor interrupts
Servo_IsAutoMoving
Servo_IsAutoMoving
Is the AutoMoveToPosition movement complete. Returns 1 if the servos are still moving. Returns 0 if all servo movement is complete.
Servo_IsServoAutoMoving
Is the AutoMoveToPosition movement complete for a specific servo output. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
- BYTE Channel
Servo Motor Output Range: 0-7
Servo_MoveToPosition
Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
- BYTE Channel
- BYTE Position
Target position to move towards. Range: 0-255
Servo_MoveToPositionInt
- BYTE Channel
- UINT Position
Target position to move towards. Range: 0-65535
Servo_SetAutoMoveSpeed
Sets the speed of the auto move to position macro. Default speed is shown in the Servo_Period_Multiplier property.
- BYTE Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
Servo_SetAutoMoveSpeedInt
- UINT Speed
Servo_SetPosition
Servo_SetPosition
Moves directly to the specified position with no interpolation.
- BYTE Channel
- BYTE Position
Position to jump to. Range: 0-255
Servo_SetPositionInt
Moves directly to the specified position with no interpolation. Uses a 16-bit position parameter to add extra precision.
- BYTE Channel
- UINT Position
Position to jump to. Range: 0-65535
Servo_SetTrim
Servo_SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
- BYTE Channel
- BYTE Trim
Legacy: 0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us or Smooth: 0-200
Stepper_DecrementStep
Move the motor backwards by one step.
Stepper_DisableMotor
Turn off the motor. It will no longer respond to any other macros.
Stepper_EnableMotor
Stepper_EnableMotor
Turn on the motor. This must be done before it will respond to any other macros.
Stepper_IncrementStep
Move the motor forward by one step.
Connection Type
DC Feedback type
Select if the feedback is a digital or analogue value. Note, if using an Arduino shield and port D is selected, then only digital type will be available.
Port
Port C is not available on the Arduino shield, If port C is slected, it will default to port B.
Servo
Trim
Pulse Width
Minimum (us)
Shortest pulse width that will be used in microseconds.
Maximum (us)
Longest pulse width used for the PWM signals in microseconds..
Period Multiplier
Number of instructions for 1 / 256th of the positional accuracy. This sets the default movement speed to maintain legacy move speeds. Also sets the multiplication factor to convert from a byte 0-255 to a clocked position value.
