Component: LCD (EB005) (E-blocks 1)
| Version | 1.1 |
| Category | E-blocks 1 |
LCD component
LCD based on the unit used in the Matrix EB005 E-block
Please click here to download the component source project: FC_Comp_Source_LCD_EB005.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_EB005.fcfx
Example of a typical LCD pinout.
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
A simple example that shows how to use some common functions.
Clear
|   | Clear |
| Clears the entire contents of the display. | |
|  - VOID | Return |
ClearLine
Command
Cursor
PrintAscii
|   | PrintAscii |
| Takes the ascii value for a character and prints the character | |
|  - BYTE | character |
| Holds an ascii value. | |
|  - VOID | Return |
PrintFormattedNumber
|   | PrintNumber |
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 | |
|  - INT | Number |
| Enter the number or variable to print to the LCD | |
|  - VOID | Return |
PrintString
|   | PrintString |
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro | |
|  - STRING | Text |
| Enter the text or variable to print to the LCD | |
|  - VOID | Return |
RAMWrite
RawSend
|   | RawSend |
| Sends data to the LCD display | |
|  - BYTE | data |
| The data byte to send to the LCD | |
|  - BOOL | type |
| A boolean to indicate command type: true to write data, false to write a command | |
|  - VOID | Return |
RemapCharacter
ScrollDisplay
|   | ScrollDisplay |
| Scrolls the display left or right by a number of given positions. | |
|  - BYTE | Position |
| Holds the number of positions to shift the display | |
|  - BYTE | Direction |
| 0 = left, 1 = right | |
|  - VOID | Return |
Start
|   | Start |
| Startup routine required by the hardware device. Automatically clears the display after initialising. | |
|  - VOID | Return |
