Component: GLCD Bitmap Drawer FAT (Graphical Library)
Revision as of 10:29, 20 April 2023 by BenR (talk | contribs) (→Examples)
Version 2.2
Category Graphical Library
GLCD Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
Please click here to download the component source project: FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
Here is an example that will scan for bitmap files in the root of the SD card and display them on a graphical display.
Bitmap Drawer File Demo
Display_BMP
Display_BMP
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
Bitmap file to open from current directory on SD card 8.3 format
- UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
- UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
- BYTE Orientation
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
- BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
- BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Display_BMP_Fast
Display_BMP_Fast
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Attempts to draw a row at a time by not forcing coordinates for every pixel so may not work on some displays. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
- UINT X
- UINT Y
- BYTE Orientation
- BYTE Transparency
- BYTE Flip
GetHeight
GetHeight
Returns the height of the loaded bitmap file in pixels.
- STRING Filename
The filename of the bitmap we want to measure
GetWidth
GetWidth
Returns the width of the loaded bitmap file in pixels.
- STRING Filename
SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
- BYTE R
- BYTE G
- BYTE B
GLCD LinkTo
File LinkTo
ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
