Component: GLCD Bitmap Drawer FAT (Graphical Library)
Revision as of 10:31, 20 April 2023 by BenR (talk | contribs) (→Examples)
Version 2.2
Category Graphical Library
GLCD Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
Please click here to download the component source project: FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
Here is an example that will scan for bitmap files in the root of the SD card and display them on a graphical display.
Bitmap Drawer File Demo
The zip file contains the Flowcode project as well as some example bitmap image files taken from Pixabay.
Place the bitmap files on the root of the SD card for the embedded hardware to work.
Display_BMP
Display_BMP
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
Bitmap file to open from current directory on SD card 8.3 format
- UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
- UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
- BYTE Orientation
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
- BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
- BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Display_BMP_Fast
Display_BMP_Fast
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Attempts to draw a row at a time by not forcing coordinates for every pixel so may not work on some displays. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
- UINT X
- UINT Y
- BYTE Orientation
- BYTE Transparency
- BYTE Flip
GetHeight
GetHeight
Returns the height of the loaded bitmap file in pixels.
- STRING Filename
The filename of the bitmap we want to measure
GetWidth
GetWidth
Returns the width of the loaded bitmap file in pixels.
- STRING Filename
SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
- BYTE R
- BYTE G
- BYTE B
GLCD LinkTo
File LinkTo
ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
