Component: Oven Simulation (Scenarios)
Revision as of 13:32, 17 May 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Scenarios
Oven Simulation component
Component designed to provide a simple simulation of a real world oven. Can be used with a simple controller such as on/off to create a standard kitchen oven. Can be used with a more complex controller such as PID to create a high accuracy temperature oven e.g. a SMD reflow oven.
Please click here to download the component source project: FC_Comp_Source_OvenSim.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_OvenSim.fcfx
An example showing 4 x 7seg LED's counting up using timer 2 interrupt
7Segment Demo
OutputAnalogue
OutputAnalogue
Switch the oven element partially on, probably using something like PWM connected via a TRIAC or FET.
- FLOAT Value
Range: 0.0 (OFF) to 1.0 (ON)
OutputOff
OutputOff
Switch the oven element off, probably using something like a relay.
OutputOn
OutputOn
Switch the oven element on, probably using something like a relay.
ReadElementTemperature
Reads the temperature of the heater element
- FLOAT Return
ReadOvenTemperature
ReadOvenTemperature
Reads the air temperature inside the oven
- FLOAT Return
ReadPowerUsage
ReadPowerUsage
Reads the ovens power consumption in KWh.
- FLOAT Return
ResetPowerUsage
ResetPowerUsage
Resets the recorded power usage to 0KWh
Element Control Pin
Thermal Characteristics
Ambient Room Temperature
Temperature of the surrounding environment
Max Element Temperature
Max temperature of the heater element when activated.
Element to Oven Coefficient
Ratio of the heat from the element passed to the heat of the air inside the oven per second.
Element Heat Coefficient
Ratio of the max element temperature added to the element when powered on per second.
Oven to Ambient Coefficient
Ratio of the oven temperature lost to ambient per second.
Electrical Characteristics
Control Voltage AC (V)
Voltage used to drive the heater element in VAC
RMS Voltage (V)
The effective constant voltage being applied
Element Resistance (Ohm)
Resistance of the element in Ohms
Control Current (A)
Instantaneous Power (W)
Calculation Period (ms)
