Component: RF Transceiver (nRF24L01) (Wireless)
Revision as of 15:00, 17 May 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd. |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gra...")
Author Matrix Ltd.
Version 2.0
Category Wireless
RF Transceiver (nRF24L01) component
A simple RF communications module based on the 2.4GHz nRF24L01 transceivermodules.
Please click here to download the component source project: FC_Comp_Source_nRF24L01.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_nRF24L01.fcfx
Example program transmitting a count value, echoing the count and TX status to the UART for debugging.
RF Test TX
Example program receiving a value, echoing any received values to the UART for debugging.
RF Test RX
CheckRX
CheckRX
Check the Rx FIFO status register for any new data. Returns 0 = No data Returns 1 = New data available
FlushRx
FlushRx
Tells the RF module to flush the contents of the receive buffer. Returns the status from sending the command.
FlushTx
FlushTx
Tells the RF module to flush the contents of the transmit buffer. Returns the status from sending the command.
Starts up and configures the RF module ready for use. The macro will return a value greater then 0 if the module has been started correctly, otherwise the macro will return a 0.
ReadRegister
ReadRegister
Reads a single bytes from the selected register. Directly returns the value read back from the register.
- BYTE Reg
Register address to access
ReadRxArray
ReadRxArray
Reads an array of bytes back from the local Rx buffer.
- BYTE Data
Byte array to store the received data
- BYTE NumBytes
Range: 1-32
ReadRxByte
ReadRxByte
Reads a single byte back from the local Rx buffer.
- BYTE Index
Byte to read, range 0 - 31
ReadRxFifo
ReadRxFifo
Reads the Rx FIFO buffer into a local buffer. Use the ReadBuffer/ReadArray macros to collect the individual data bytes.
SetRxMode
SetRxMode
Sets up the module up ready to receive data. Assigns the 5-byte pipe listen address.
- BYTE PA0
Pipe Address Bytes
- BYTE PA1
Pipe Address Bytes
- BYTE PA2
Pipe Address Bytes
- BYTE PA3
Pipe Address Bytes
- BYTE PA4
Pipe Address Bytes
SetTxMode
SetTxMode
Sets the module up ready to transmit data. Assigns the 5-byte pipe transmit address.
- BYTE PA0
Pipe Address Bytes
- BYTE PA1
Pipe Address Bytes
- BYTE PA2
Pipe Address Bytes
- BYTE PA3
Pipe Address Bytes
- BYTE PA4
Pipe Address Bytes
WriteRegister
WriteRegister
Writes a single byte to the selected register. Returns the status of the write command.
- BYTE Reg
- BYTE Value
WriteTxArray
WriteTxArray
Writes an array of bytes to the local Tx buffer.
- BYTE Data
Byte array to write.
- BYTE NumBytes
Range: 1-32
WriteTxByte
WriteTxByte
Writes a single byte to the local Tx buffer.
- BYTE Index
- BYTE Value
WriteTxFifo
WriteTxFifo
Writes the contents of the local Tx buffer to the Transmit FIFO and transmits. Returns 1 if transmission was sucessful.
- BOOL Return
RF Settings
RF Channel
Sets the RF channel from 0 - 127 = 2.4000GHz - 2.525GHz Both the transmitter and receiver should be on the same channel to receive data. Default 76 is a relatively free channel meaning there should be little interference here.
TX Power
Amount of power used for the transmitter circuit.
Data Rate
Sets the data throughput rate.
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
CE Pin
Chip enable, configures RX or TX mode
API
