Component: Output Digital (DSP Outputs)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP Outputs |
Output Digital component
Allows the values from a buffer to be read. Either a value at a time or as an array.
Please click here to download the component source project: FC_Comp_Source_DSP_Output.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Output.fcfx
GetByte
GetByte |
Returns a byte value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
Return |
GetByteArray
GetByteArray |
Returns an array of byte values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
Data |
Count |
Return |
GetFloat
GetFloat |
Returns a float value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
Return |
GetFloatArray
GetFloatArray |
Returns an array of float values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
Data |
Count |
Return |
GetInt
GetInt |
Returns an integer value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
Return |
GetIntArray
GetIntArray |
Returns an array of integer values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
Data |
Count |
Return |
GetLong
GetLong |
Returns a long value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
Return |
GetLongArray
GetLongArray |
Returns an array of long values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
Data |
Count |
Return |
