Component: Energy Monitor (PZEM-004T) (Electrical)
Revision as of 06:48, 20 July 2023 by MartinW (talk | contribs) (→Examples)
Author Matrix Ltd.
Category Electrical
Energy Monitor (PZEM-004T) component
The PZEM-004T module is used for measuring AC voltage, current, active power, frequency, power factor & overcurrent. Resetable active energ and the overpower level can be set and monitored.
Please click here to download the component source project: FC_Comp_Source_Energy_Monitor_PZEM-004T.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Energy_Monitor_PZEM-004T.fcfx
Notes: if there is a communication issue after initialisation, then just 9's will be returned!
The TX of the PZEM-004T energy monitor goes to RX of the Arduino Uno
The RX of the PZEM-004T energy monitor goes to TX of the Arduino Uno 'The PZEM-004T must be disconnected from the RX of the Uno prior to programming. After reconnecting press the Reset button on the Uno
WARNING: MAINS CAN KILL. ONLY TRY THIS IF ARE EXPERIENCED WITH MAINS ELECTRICITY. WIRE AT YOUR OWN RISK!
This example program uses a PZEM-004T energy monitor to monitor mains voltage, current, frequency, power factor, energy, and over-threshold power alarm. The alarm threshold is set within properties. Initialiasion returns 0 if PZEM-004T is detected or 255 if it is not. Values are sent to the ESP32 TTGO display which uses a ST7789v1 GLCD.
ESP32 TTGO Mains PM v1.3
This example uses the Arduino Uno and outputs UART via the Timer UART component on pin D2 at a baud rate of 19200. All the functions are the same as above but no display is used. D3 and D4 have pullups so no external resistors are required. Each switch is pulled to GND to trigger.
Arduino Uno Mains PM v1.0
Starts up the UART to allow communications. Also, checks if PZEM-004T is detected. Returns 0 if detected or 255 if not detected.
ReadAlarmStatus
ReadAlarmStatus
65535 = Overpower alarm triggered. 0 = Overpower alarm not triggered.
ReadCurrent
ReadCurrent
Read what the current draw is. Resolution: 0.001A Measurement accuracy: 0.5%
- FLOAT Return
ReadEnergy
ReadEnergy
Read active energy value. Resolution: 1Wh Measurement accuracy: 0.5%
- FLOAT Return
ReadFrequency
ReadFrequency
Reads the frequency of the mains
- FLOAT Return
ReadPower
ReadPower
Read active power. Starting measure power: 0.4W Resolution: 0.1W
- FLOAT Return
ReadPowerAlarmThreshold
Reads the power alarm threshold in watts
ReadPowerFactor
ReadPowerFactor
Read power factor Resolution: 0.01 Measurement accuracy: 1%
- FLOAT Return
ReadVoltage
ReadVoltage
Read voltage. Measuring range:80~260V Resolution: 0.1V Measurement accuracy: 0.5%
- FLOAT Return
ResetEnergy
ResetEnergy
Reset the energy value
SetPowerThresholdLevel
Sets the power alarm threshold in watts
- UINT PowerThresholdValue
Reg addreess high of alarm threshold
UART Properties
TX
RX
Baud Options
Bus
Specifies the bus mode being used, RS232 allows you to connect a single master node to a single slave node. RS485 allows you to connect a single master node to multiple slave nodes.
Modbus Properties
Receive Buffer Size
Slave ID Bytes
Silent Interval
Configures how much time to wait after each master modbus command before another command can be sent. A silent interval of 60ms minimum is required in order to guarentee successful reception of the next transmission. 0=No Delay 60 = 60mS - Default Range : 0 - 65535
UART Receive Timeout
Amount of time to wait before timing out when listening for a slave's response. Range: 0 - 255. 0 = Don't Wait 1 - 254 = X ms 255 = Wait Forever
Receive Timeout Count
Number of timeouts in a row to wait for until we decide the slave is not responding or finished responding to a message. Range: 0 - 255 0 = First Timeout Only 1 = First Timeout + 1 2 = First Timeout + 2
Simulation Properties
Console Columns
Data Source
