Component: CAN Bus BL0140 (E-blocks 2)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs)
Author
Category E-blocks 2
CAN_Bus_BL0140 component
Please click here to download the component source project: FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
ChangeRate
ChangeRate
Simple attempt to alter the bus rate of the CAN. External CAN channels only,
- BYTE Rate
Rate: 0-3 where 0=125, 1=250, 2=500, 3=1000
CheckRx
CheckRx
Checks to see if any messages are available for 'Buffer' specified
- BYTE Buffer
Send buffer: 0 to 1
GetRxData
GetRxData
Returns last received message data byte at position Index. Buffer parameter is currently ignored
- BYTE Buffer
- BYTE Index
GetRxDataCount
GetRxDataCount
Returns last received message data length. Buffer parameter is currently ignored
- BYTE Buffer
GetRxIDHi
GetRxIDHi
Gets the Hi byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE Buffer
Receive Buffer. Range 0-1
GetRxIDLo
GetRxIDLo
Gets the Lo byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE Buffer
GetRxIDSimple
GetRxIDSimple
Gets the Rx ID as a Integer Standard ID only 0-2047.
- BYTE Buffer
GetRxIdent
GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
- BYTE Buffer
- ULONG Return
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
ReadSwitches
ReadSwitches
Returns switch input states from the external MCP2515 device. 0 = No Switch Pressed, 1 = Switch 1 Pressed, 2 = Switch 2 Pressed, 3 = Both Pressed (External CAN only)
SendBuffer
SendBuffer
Transmits one of the transmit buffers which should have already been populated with an ID and data.
- BYTE Buffer
Specifies which transmit buffer to send
SetRxFilter
SetRxFilter
Allows the receive ID filter to be configured on the fly allowing different ID ranges to be received.
- BYTE Filter
Specifies which receive filter to modify. Range: 0-5
- ULONG ID
The ID filter value you wish to use
SetRxFilterID
SetRxFilterID
sets the Filter Standard mode only (for V5 compatibility only)
- BYTE Filter
Specifies which filter to modify. Range: 0-5
- BYTE Hi
ID bits 3-10
- BYTE Lo
ID bits 0-2 stored in the upper 3 bits of the byte
SetRxMask
SetRxMask
Allows the receive ID mask to be configured on the fly allowing different ID ranges to be received.
- BYTE Mask
Specifies which receive mask to modify. Range: 0-1
- ULONG ID
The ID mask value you wish to use
SetRxMaskID
SetRxMaskID
set the Mask Standard ID mode only (for V5 compatibility)
- BYTE Mask
- BYTE Hi
ID bits 3-10
- BYTE Lo
SetTxData
SetTxData
Assigns one of the outgoing transmit buffers with data ready to be sent.
- BYTE Buffer
- BYTE Count
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
SetTxID
SetTxID
Set the Tx CAN ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE Buffer
Transmit buffer to load. Range: 0-2
- BYTE Hi
ID bits 3-10 e.g. ((ID & 0x7F8) >> 3)
- BYTE Lo
ID bits 0-2 stored in the upper 3 bits of the byte e.g. ((ID & 0x7) << 5)
SetTxIDSimple
SetTxIDSimple
Set the Tx CAN ID as a generic number. Standard IDs only 0-2047.
- BYTE Buffer
- UINT ID
The ID value you wish to use. Range: 0-2047
SetTxIdent
SetTxIdent
Set the Tx CAN ID as a generic number. Standard and extended IDs Standard 0-2047 Extended 2048-536870911
- BYTE Buffer
- ULONG ID
The ID or Extended ID value you wish to use. Range: 0-536870911
ShowLEDs
ShowLEDs
Set LED state (External CAN only)
- BYTE led1
Controls LED 1. Range: 0-1
- BYTE led2
Controls LED 2. Range: 0-1
SPI
External/Internal
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
CHANNEL
SPI Channel selector
Port
INT
CS (SS)
MOSI
MISO
CLK
Prescale
Prescale option selector
Sample Point
Data bit read sample point
Config Delay
TX Buffer 0
Message ID
TX Buffer 0 Message Identifier
Length
TX Buffer 0 Number of data bytes
D0
TX Buffer 0 Data Byte 0
D1
TX Buffer 0 Data Byte 1
D2
TX Buffer 0 Data Byte 2
D3
TX Buffer 0 Data Byte 3
D4
TX Buffer 0 Data Byte 4
D5
TX Buffer 0 Data Byte 5
D6
TX Buffer 0 Data Byte 6
D7
TX Buffer 0 Data Byte 7
TX Buffer 1
Message ID
TX Buffer 1 Message Identifier
Length
TX Buffer 1 Number of data bytes
D0
TX Buffer 1 Data Byte 0
D1
TX Buffer 1 Data Byte 1
D2
TX Buffer 1 Data Byte 2
D3
TX Buffer 1 Data Byte 3
D4
TX Buffer 1 Data Byte 4
D5
TX Buffer 1 Data Byte 5
D6
TX Buffer 1 Data Byte 6
D7
TX Buffer 1 Data Byte 7
TX Buffer 2
Message ID
TX Buffer 2 Message Identifier
Length
TX Buffer 2 Number of data bytes
D0
TX Buffer 2 Data Byte 0
D1
TX Buffer 2 Data Byte 1
D2
TX Buffer 2 Data Byte 2
D3
TX Buffer 2 Data Byte 3
D4
TX Buffer 2 Data Byte 4
D5
TX Buffer 2 Data Byte 5
D6
TX Buffer 2 Data Byte 6
D7
TX Buffer 2 Data Byte 7
RX Buffer 0
Settings
RX Buffer 0 Message Receive Mode
RX Buffer 1
Settings
RX Buffer 1 Message Receive Mode
Simulate SPI Comms
