Component: File (ESP32 SDMode) (File)
| Author | Matrix Ltd. |
| Version | 2.7 |
| Category | File |
File (ESP32 SDMode) component
File component allowing access to read and write files on an SD card using the ESP32 SD Mode IO allowing for high speed data transfer using 1-bit or 4-bit SD access.
Please click here to download the component source project: FC_Comp_Source_File_ESP32_SDMode.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_File_ESP32_SDMode.fcfx
Line Following
Line following example using the Formula AllCode, works with objects on the simulation panel and on the real hardware.
Simulation with the API component
An example showing how to use the API component to drive the robot in simulation.
AppendByteToFile
| AppendByteToFile | |
| Data | |
AppendStringToFile
| AppendStringToFile | |
| Data_String | |
CloseFile
| CloseFile | |
CreateFile
| CreateFile | |
| Filename | |
DeleteFile
| DeleteFile | |
| Filename | |
| Starts up the SD card interface and checks to see if a card is compatible. Returns: 0=OK, 255=No Card, 254=File System Fail | |
MoveToNextFileSector
| MoveToNextFileSector | |
| Not currently implemented on the RPI | |
| ForceNextSector | |
OpenFile
OpenFolder
| OpenFolder | |
| Folder_Name | |
ReadByteFromFile
ReadByteFromIndex
| ReadByteFromIndex | |
| Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer. | |
| Address | |
ReadFileLength
| ReadFileLength | |
ReadFileSize
| ReadFileSize | |
| Reads the entire size of the current file in bytes. | |
ReadStringFromFile
SetFileIndex
| SetFileIndex | |
| File_Index | |
| Range: 0 to 4 | |
Uninitialise
| Uninitialise | |
| Terminates connection to the SD card, unmounts the SD card and disabled the SD peripheral. | |
WriteByteToBuffer
| WriteByteToBuffer | |
| Address | |
| Data | |
WriteFileSector
| WriteFileSector | |
