Component: GLCD (EB043 v1) (E-blocks 1)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs)
Version 1.3
Category E-blocks 1
GLCD (EB043 v1) component
Graphical display component designed to work with the legacy version 1 EB043 E-blocks.
Please click here to download the component source project: FC_Comp_Source_GLCD_EB043-00-1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_EB043-00-1.fcfx
EB043 v1 gLCD Example File FC6 Icon.png EB043 Example Example should show the following on the display on the panel and on the hardware.
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
Chooses the transparency of the box - 0 = Box contains background colour, 1 = Box contains previous pixel data
FastPlot
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
Window
Fc9-comp-macro.png Window
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Data
Data pin connection
Fc9-type-5-icon.png Clock
Clock pin connection
Fc9-type-5-icon.png Chip Select
Chip select pin connection
Fc9-type-5-icon.png Reset
Reset pin connection
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
