Component: Bitmap Drawer (Displays: Graphical)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Displays: Graphical
Bitmap Drawer component
A component to simplify the process of drawing bitmap images to a graphical display. Stores the bitmap image inside a ROM look up table. Compatible with 24-bit Bitmaps and Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Use multiple BitmapDrawer components for multiple bitmap images.
Please click here to download the component source project: FC_Comp_Source_Lib_GLCD_Menu_Unfinished.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_GLCD_Menu_Unfinished.fcfx
The graph creator XY component must be linked to the graphical LCD using the gLCD Object property.
The X Coord, Y Coord, Width and Height component properties set the size and position of the graph on the gLCD.
In the attached example the ADC component sets the input to the graph. Every 50ms a sample is taken and added to the graph.
FC6 Icon.png Graph Creator Demo
Any size of graph can be created. For efficiency it is best to try and stick to the following rules.
  • The width should be equal to or a multiple of the X input range - Min Value 0 to Max Value 255 = input range of 256
  • The height should be equal to or a multiple of the Y input range - Min Value 0 to Max Value 255 = input range of 256
  • If Show Border is enabled then Width and Height should be as above plus 2 to account for the border pixels
Fc9-comp-macro.png Initialise
Configures the menu and assigns the coordinates on the LCD.
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-u16-icon.png - UINT Width
Fc9-u16-icon.png - UINT Height
Fc9-u8-icon.png - BYTE Font
Fc9-type-17-icon.png gLCD Object
Graphical LCD Object to draw the bitmap image to
Fc9-type-21-icon.png Max Items
Sets the maximum number of menu items available.
Fc9-type-21-icon.png Max Item Length
Sets the maximum number of bytes to reserve for each menu item
Fc9-type-16-icon.png MarkerStyle
Fc9-type-1-icon.png Foreground Colour
Fc9-type-7-icon.png ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
