Component: Grove I2C Motor Driver (Mechatronics)
Revision as of 11:29, 20 October 2023 by BenR (talk | contribs)
Category Mechatronics
Grove I2C Motor Driver component
A grove board based around the L298P motor driver IC allowing control of two DC motors or a single stepper motor.
Please click here to download the component source project: FC_Comp_Source_Grove_I2C_Motor_Driver.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Grove_I2C_Motor_Driver.fcfx
Frequency
Fc9-comp-macro.png Frequency
Set the frequency of PWM (cycle length = 510, system clock = 16MHz)
Fc9-u8-icon.png - BYTE FrequencySelection
1=31.372 KHz, 2=3.921 KHz, 3=490 Hz, 4=122 Hz, 5=30 Hz
Fc9-comp-macro.png Initialise
Sets up the I2C ready for communications
Speed
Fc9-comp-macro.png Speed
Sets the speed of a motor.
Fc9-u8-icon.png - BYTE Motor
1=Motor1 / 2=Motor2
Fc9-s16-icon.png - INT Speed
Range: -255 to 255 where -255 = Full Backwards, 0=Stop, 255=Full Forwards
Stop
Fc9-comp-macro.png Stop
Stop one motor
1 = Motor1 / 2 = Motor2
Fc9-conn-icon.png Communications
Fc9-type-16-icon.png I2C Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-type-16-icon.png Default Frequency
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Specifies the API component on the panel to interact with to provide comms simulation.
