| Author
Matrix TSL
| Version
2.0
| Category
LEDs
RGB LED APA102C component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
Here is an example that lights the LEDs up Red, Green and then Blue for a second. The program then goes into a loop where a colour is assigned to LED0 and then shifted through the other chained LEDs. the colour assigned to LED0 will slowly fade and be slightly randmised to allow some colour variation during operation.
APA102C Demo
DrawCuboid3D
DrawCuboid3D
| Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
Z1
- BYTE
X2
- BYTE
Y2
- BYTE
Z2
- BYTE
DrawStyle
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE
R
- BYTE
G
- BYTE
B
DrawLine2D
DrawLine2D
| Draws a line on a 2D array of LEDs
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
R
- BYTE
G
- BYTE
B
DrawLine3D
DrawLine3D
| Draws a line on a 3D array of LEDs
- UINT
X1
- UINT
Y1
- UINT
Z1
- UINT
X2
- UINT
Y2
- UINT
Z2
- BYTE
R
- BYTE
G
- BYTE
B
DrawRectangle2D
DrawRectangle2D
| Draws a basic 2D rectangle onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
- BYTE
R
- BYTE
G
- BYTE
B
GetLEDColour
GetLEDColour
| Sets the colour of a single LED in RAM as a 1D array.
- UINT
LED
| LED to change the colour / Range: 0 to (LED Count - 1)
- BYTE
ColIdx
| 0 = R, 1 = G, 2 = B
- BYTE
GetLEDIndex2D
GetLEDIndex2D
| Sets the index of a single LED in RAM as a 2D array.
- UINT
X
| LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT
Y
| LED Row to change the colour / Range: 0 to (LED Row - 1)
- UINT
GetLEDIndex3D
GetLEDIndex3D
| Gets the index of a single LED in RAM as a 3D array.
- UINT
X
- UINT
Y
- UINT
Z
| LED Layer to change the colour / Range: 0 to (LED Layer - 1)
- UINT
| Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the WS2801 ICs in the chain.
Refresh
Refresh
| Clocks out the current colour data to the LEDs from the values stored in RAM
SetAllLEDColour
SetAllLEDColour
| Sets the colour of all the LEDs in RAM
- BYTE
R
- BYTE
G
- BYTE
B
SetBrightness
SetBrightness
| Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
- FLOAT
Scaler
| Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
SetBrightnessByte
SetBrightnessByte
- BYTE
Scaler
| Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
SetLEDColour
SetLEDColour
- UINT
LED
- BYTE
R
- BYTE
G
- BYTE
B
ShiftLEDs1D
ShiftLEDs1D
| Shifts the LED colours in 1D and wraps
- BYTE
Direction
| 0 = Forwards, 1 = Backwards
- BYTE
DataMode
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
ShiftLEDs2D
ShiftLEDs2D
| Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
- INT
X
| Number of pixels to shift the display -1 to 1 / 0 = No Shift
- INT
Y
- BYTE
DataMode
ShiftLEDs3D
ShiftLEDs3D
- INT
X
- INT
Y
- INT
Z
- BYTE
DataMode
LED Properties
LED Arrangement
| Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
LED Count
| Total number of LEDs in the design
Column Spacing
| X Spacing Between LEDs on the Panel
LED Current Usage
Output Mode
| Sets the output mode used to drive the data to the LEDs Bit Banged Mode = Allows Any I/O Pin but may be slower SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O
Connection Properties
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
API
==Component Source Code==
Please click here to download the component source project: FC_Comp_Source_LED_APA102C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_APA102C.fcfx
