Component: Touch Screen (XPT2046) (Graphical Library)
Revision as of 08:55, 19 January 2024 by MartinW (talk | contribs) (→Examples)
Version 2.0
Category Graphical Library
Touch Screen (XPT2046) component
Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found on a lot of common low cost resistive touch screen products.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_XPT2046.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_XPT2046.fcfx
Example using the XPT2046 touchscreen driver IC with a 4.3" TFT Display using the SSD1963 Graphical LCD Controller. GLCD 4.3 Touch
Example using the XPT2046 touchscreen driver IC with a 7" TFT Display using the SSD1963 Graphical LCD Controller. GLCD 7 Touch
Activates the SPI peripheral and claims control over the I/O pins.
ReadCoord
ReadCoord
Reads a coordinate returned from the Sample Sensor macro. Coordinate is scaled to the X/Y Pixel bounds specified.
- BYTE Coordinate
0 = X, 1 = Y, 2 = Pressure
SampleSensor
SampleSensor
Reads the touch controller and returns true if there is currently a touch in progress. The touch coordinates can be read using the ReadCoord macro. Return 0 = No Touch, 1 = Touch in progress
LinkTo
Bus Settings
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Configuration
Analogue Mode
X Pixel
Y Pixel
Flip X
Flip Y
Label used to identify the component on the panel.
Enable Interrupt
Allows the simulated display to fire an interrupt to allow you to action inputs as they happen.
Interrupt Macro
Macro called when the simulated display fires an interrupt.
Simulate Comms
Allows the SPI communications to be simulated and piped through an API to real world hardware.
