| Author
Matrix TSL
| Version
2.1
| Category
Misc
SPI component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Serial Peripheral Interface peripheral.
GetConsoleHandle
GetConsoleHandle
| Returns a handle to the console used by this component
- HANDLE
GetList
GetList
| returns Named property list
- STRING
Name
- STRING
GetValue
GetValue
| Reads Named property Value.
- STRING
Name
- STRING
Master_Byte
Master_Byte
| Sends and receives a data byte
- BYTE
DataOut
- BYTE
Master_Disable_CS
Master_Disable_CS
| Outputs a high signal to the chip select pin to deselect the remote slave device.
Master_Enable_CS
Master_Enable_CS
| Outputs a low signal to the chip select pin to select the remote slave device.
Master_Init
Master_Init
| Initialise the Master
- BYTE
Master_Transaction
Master_Transaction
| Sends and receives data bytes via the SPI channel. The Buffer is to contain the data to be sent, and is overwritten by the retuning data from the device. Returns 1 for success, 0 for failure
- BYTE
Buffer
- UINT
Length
| Number of bytes to transfer
- BYTE
Master_Uninit
Master_Uninit
| Uninitialise the Master
Prv_TextConsole
Prv_TextConsole
| Send text to the SPI console. Exposed as part of the CAL_SPI component to allow none AutoCS pins and other.
- STRING
str
- BYTE
Colour
| 0=Default, 1=TX, 2=RX
- BYTE
AppendTimestamp
| 0=Don't Append / 1=Do Append
SetPrescaler
SetPrescaler
| Sets the prescaler value for the clock divider chain
- BYTE
Prescaler
SetValue
SetValue
| Change Named property to new Value.
- STRING
Name
- STRING
Value
Slave_Init
Slave_Init
| Initialise the Slave
Slave_RxByte
Slave_RxByte
| Returns the data received from the SPI Master
- BYTE
Slave_TxByte
Slave_TxByte
| Sets the data to be transmitted to the SPI master.
- BYTE
Data
Slave_Uninit
Slave_Uninit
| Uninitialise the Slave
Component Enable
| A global flag to enable or disable the SPI component from producing code. Useful for generating components with multiple communications options.
| SPI Channel selector
MOSI
MISO
CLK
Use Auto CS
| Allow the SPI component to manage the CS pin for us in Master mode. On initialise the CS pin is automatically set high to disable the remote SPI device. Set to No if you want to create a component with multiple CS pins or if you want to manage the CS pin yourself.
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
CS Polarity
Options
Mode
| Configures the mode of the SPI component. Currently only Master mode is supported.
Prescale
| Prescale option selector
Clock Phase
| Clock Phase (data change edge) selection
Clock Polarity
| Clock Polarity setting, inactive (idle) state
Sample Point
| Data bit read sample point
API
| Selects the API Slave to use to send and receive real world SPI data during simulation.
Please click here to download the component source project: FC_Comp_Source_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI.fcfx
