| Author | Matrix Ltd |
| Version | 1.6 |
GLCD (SSD1322) Buffered component
Graphical display component based on the SSD1322 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the  microcontroller's RAM memory.
BPlot
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
ClearDisplay
|   | ClearDisplay |
|  - VOID | Return |
DrawCircle
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Transparent |
|  - BYTE | Solid |
|  - VOID | Return |
DrawEllipse
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
DrawLine
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
DrawRectangle
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
Plot
|   | Plot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
Print
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - VOID | Return |
ReadFontStat
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
ReadFontWidth
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Character |
|  - BYTE | Return |
SetBackgroundColour
|   | SetBackgroundColour |
| Specifies the colour of the background by creating a mixture of red, green and blue. |
|  - BYTE | PixelColour |
| 0=White, 1=Black |
|  - VOID | Return |
SetDisplayOrientation
|   | SetDisplayOrientation |
|  - BYTE | Orientation |
|  - VOID | Return |
SetFontScaler
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
SetForegroundColour
|   | SetForegroundColour |
| Specifies the colour of the foreground by creating a mixture of red, green and blue. |
| 0=White, 1=Black |
|  - VOID | Return |
SetShadeIntensity
|   | SetShadeIntensity |
| Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15 |
|  - BYTE | Shade |
| Range: 1-15 / 1=Dim / 15 = Bright |
|  - VOID | Return |
|   | Properties |
|   | Dimensions |
|   | Pixel Width |
|   | Pixel Height |
|   | Colour |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Bit Depth |
|   | Colour Bit Depth |
|   | Red Bit Depth |
|   | Green Bit Depth |
|   | Blue Bit Depth |
|   | Connections |
|   | Chip Select (CS) |
| Chip select output control pin |
|   | Data (SD) |
| Serial data output control pin |
|   | Serial Clock (SCK) |
| Serial clock output control pin |
|   | Reset (RST) |
| Reset control pin |
|   | Connection Type |
|   | Clock Delay |
| Number of microseconds to wait after each clock edge. Recommend 1 for faster devices and 0 for slower devices. |
|   | Fonts |
|   | Font Count |
|   | Font 0 |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Simulation Mode |
|   | Component Label |
|   | Component Label Scale |
| The label scale can be change if the amout of text is too wide for the display |
|   | Physical Orientation |
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1322_buffered.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1322_buffered.fcfx
