Component: Display Manager (Graphical Library)
Revision as of 11:15, 10 April 2024 by BenR (talk | contribs) (→Examples)
Author MatrixTSL
Version 2.0
Category Graphical Library
Display Manager component
The component can create the follow objects.
  • Type_Line - 2 - A simple straight line.
  • Type_Rectangle - 1 - A simple rectangular box.
  • Type_RectangeFilled - 5 - A filled rectangular box.
  • Type_Ellipse - 3 - A simple ellipse or circle.
  • Type_EllipseFilled - 4 - A filled ellipse or circle.
  • Type_TextBox - 0 - A text area allowing a line of text to be displayed.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Type_TextBox
An example showing how to use the display manager with a GLCd and a touch interface to create a full HMI.
Display Manager Demo
CheckForTouch
CheckForTouch
Uses the X and Y coordinates from a touch sensor to check for button presses. Returns 0 for no buttons pressed. Returns 1 for a valid button press. The ID of the pressed item can be found by calling GetButtonID macro. Any touched slider buttons will automatically move their thumb and value to the touch position.
- UINT X
- UINT Y
- BOOL Return
ClearAll
ClearAll
Removes all objects and buttons from memory. Also clears the screen if required.
- BOOL ClearScreen
0=Don't clear the screen, 1=Clear the screen
CreateButton
CreateButton
Define an interactive button or slider. Returns the Button ID.
- BYTE ButtonType
0=ButtonHidden, 1=ButtonRect, 2=ButtonRoundedRect, 3=ButtonEllipse, 4=VSlider, 5=HSlider, 6=VSliderRound, 7=HSliderRound
- UINT X
X Pixel Coordinate
- UINT Y
Y Pixel Coordinate
- UINT Width
Pixel Width or X Radius
- UINT Height
Pixel Height or Y Radius
- BYTE Theme
Theme index to use to draw the button
- BOOL DrawButton
0=Do not draw button yet, 1=Draw button now
CreateObject
CreateObject
Define a none touchable graphical object. Returns the Object ID.
- BYTE ObjectType
0=Hidden, 1=Rect, 2=Line, 3=Ellipse, 4=FilledEllipse, 5=FilledRect
- UINT X
X Pixel Coordinate
- UINT Y
Y Pixel Coordinate
- UINT Width
- UINT Height
- BYTE Theme
Theme index to use to draw the object
- BOOL DrawObject
0=Do not draw object yet, 1=Draw object now
DrawAll
DrawAll
Redraws all of the defined Objects and Buttons. Doesn't draw text, this is done using the SetText macro.
DrawItem
DrawItem
Draws a single object or button onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro.
- UINT ID
Unique ID of the Object or Button
GetLastTouchID
GetLastTouchID
Gets the ID of the last button that returned a valid press via the CheckForTouch macro. Returns -1 for valid touch recorded.
- INT Return
GetSliderValue
GetSliderValue
Reads the value of one of the sliders ranging between 0 and 1.
- UINT ButtonID
- FLOAT Return
Initialises the object and button control variables and sets up the default themes.
ModifyPosition
ModifyPosition
Moves an existing object or button to absolute coordinates on the screen.
- UINT ID
Unique ID of the object or button
- INT X
- INT Y
- BOOL Relative
0=Absolute Positioning, 1=Relative Positioning
ModifyScale
ModifyScale
Changes the width and height of the selected Object or Button.
- UINT ID
- UINT Width
- UINT Height
ModifyTheme
ModifyTheme
Changes the theme index of the selected Object or Button.
- UINT ID
- BYTE Theme
Theme index of the button or object
NoTouch
NoTouch
Called when no touch is present, Allows the repeat rate counter to be cleared allowing for better responses to fast touches.
OverrideButtonTheme
OverrideButtonTheme
Overrides the colour of a button theme, used by the draw button macro.
- BYTE ThemeIndex
Index of the object colour theme
- BYTE FG_R
Foreground colour channel value
- BYTE FG_G
- BYTE FG_B
- BYTE BG_R
Background colour channel value
- BYTE BG_G
- BYTE BG_B
- BYTE HL_R
Highlight colour channel value
- BYTE HL_G
- BYTE HL_B
- BYTE LL_R
Lowlight colour channel value
- BYTE LL_G
- BYTE LL_B
OverrideObjectTheme
OverrideObjectTheme
Overrides the colour of an object theme, used by the draw object macro.
- BYTE ThemeIndex
- BYTE FG_R
- BYTE FG_G
- BYTE FG_B
- BYTE BG_R
- BYTE BG_G
- BYTE BG_B
SetSliderValue
SetSliderValue
Sets the value of one of the sliders and optionally redraws the slider to reflect the value change.
- UINT ButtonID
- FLOAT Value
Range: 0 to 1
- BOOL RedrawSlider
0=Do not redraw, 1=Redraw
SetText
SetText
Draws a single line of text onto an object or button location. Useful for labelling buttons or having name, value statistics. Drawn using the object themes.
- UINT ID
Unique identifier of object or button.
- STRING Text
- BYTE Font
- BYTE HAlignment
0=Left, 1=Center, 2=Right
- BYTE VAlignment
0=Top, 1=Middle, 2=Bottom
- BYTE Theme
Object theme index to control the colour of the text
- BOOL Transparent
0=Background Colour Drawn, 1=Don't Draw Background Colour
LinkTo
Ram Usage Bytes
The calculated number of bytes of RAM required by the display manager.
Text Align Offset
Number of pixels to move away from an edge when calling SetText
Objects
Max Objects
The total number of primitive objects allowed on the screen at once. Sets the size of the RAM buffers used to track the various screen elements. Each object requires 10 bytes of RAM to stores things like size, location and type.
Object Theme Count
Sets the number of themes available when drawing primitive objects. Each object theme requires 6 bytes of RAM to store the colour channels.
Theme 0
Foreground
Foreground colour of the theme
Background
Background colour of the theme
Theme 1
Foreground
Background
Buttons
Max Buttons
The total number of touchable interactibe objects allowed on the screen at once e.g. buttons and sliders. Sets the size of the RAM buffers used to track the various screen elements Each button requires 18 bytes of RAM to stores things like size, location, value and type.
Touch Repeat Rate
Sets the period for touch repeats in terms of calls of the CheckForTouch macro. Buttons will only register a repeat touch after x calls if continually held down. Sliders will always register a touch. The touch count can be cleared using the NoTouch macro if no touch is detected.
Slider Thumb Width
Number of pixels wide to make a slider thumb marker,
Slider Center Line Thickness
Number of pixels thick to draw the slider central line
Button Theme Count
Sets the number of themes available for drawng buttons. Each button theme requires 12 bytes of RAM to store the colour channels.
Theme 0
Foreground
Background
Highlight
Highlight colour of the theme
Lowlight
Lowlight colour of the theme
Theme 1
Foreground
Background
Highlight
Lowlight
