Component: Timer (Timing)
| Version | 14.0 |
| Category | Timing |
Timer component
Allows you to measure the passage of time via the use of a hardware timer peripheral. Works like a stopwatch with macros to start, stop and reset the timer counter. Returns time as integer Seconds, Milliseconds, Microseconds and also Floating Point and String.
Version information
Here is a basic example showing the operation of the timer component used to time a section of code or the duration of a specific event.
GetCountMicroSeconds
| GetCountMicroSeconds | |
| Returns the count value as a number of whole microseconds, rounded down to the nearest microsecond | |
GetCountMilliseconds
| GetCountMilliseconds | |
| Returns the count value as a number of whole milliseconds, rounded down to the nearest millisecond | |
GetCountReal
| GetCountReal | |
| Returns the count value as a floating point value in seconds. | |
GetCountSeconds
| GetCountSeconds | |
| Returns the count value as a number of whole seconds, rounded down to the nearest second | |
GetCountString
| GetCountString | |
| Returns the count value as a floating point string in seconds. | |
| Precision | |
| Number of decimal places to display in string | |
GetRawCount
| GetRawCount | |
| Efficient command to collect the integer number of instructions since the timer was started. | |
ResetCounter
| ResetCounter | |
StartCounter
| StartCounter | |
| Starts the timer counting. | |
| ResetCounters | |
| Range: 0-1 where 0=Do Not Reset and 1=Reset | |
StopCounter
| StopCounter | |
| Stops the timer counting. | |
Please click here to download the component source project: FC_Comp_Source_TimerComponent.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponent.fcfx
