Component: Display Manager (Graphical Library)
Author MatrixTSL
Version 2.1
Category Graphical Library
Display Manager component
Version information
13, 2.0, 22-05-24, BR, Added text alignment options
14, 2.1, 14-06-24, BR, Renamed Button to Widget to better include things like sliders
15, 2.1, 26-07-24, BR, Added SetTextFloat and AddTextNumber macros
16, 2.1, 29-07-24, BR, Renamed Themes to ObjectThemes and WidgetThemes
17, 2.1, 29-07-24, BR, Added CreateTextField macro which automates creating a simple textbox
Objects
The component can create the following objects.
  • Object_Hidden - 0 - A hidden area with no graphics.
  • Object_Rectangle - 1 - A simple rectangular box.
  • Object_Line - 2 - A simple straight line.
  • Object_Ellipse - 3 - A simple ellipse or circle.
  • Object_EllipseFilled - 4 - A filled ellipse or circle.
  • Object_RectangeFilled - 5 - A filled rectangular box.
TextField
There is also an additional TextField object which consists of an Object_Rectangle that is pre-populated with text.
Widgets
The component can also create the following interactive buttons and sliders.
  • Widget_Hidden - 0 - A hidden area with no graphics.
  • Widget_Rectangle - 1 - A rectangular box with a shadow.
  • Widget_RoundedRectangle - 2 - A rounded rectangular box with a shadow.
  • Widget_Ellipse - 3 - A simple ellipse or circle with a shadow.
  • Widget_VSlider - 4 - A vertical slider with a square thumb.
  • Widget_HSlider - 5 - A horizontal slider with a square thumb.
  • Widget_VSlider_Round - 6 - A vertical slider with a round thumb.
  • Widget_HSlider_Round - 7 - A horizontal slider with a round thumb.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Object_Rectangle or DisplayManager1::Widget_VSlider
Touch Repeat Rate for Button Widgets
The Touch Repeat Rate property applies to button based widgets and sets the frequency that a valid touch will be detected for a held button. This is similar to holding down a single key on a keyboard and acts to reduce the frequency of positive button detections when touching the button. For example if you had a button that incremented a value, without the repeat rate the value would increment much faster then anticipated in an uncontrollable manner. When no touch is detected it is recommended to call the NoTouch macro to clear the touch counters and allow a more responsive user experience.
Example of implementing touch repeat rate
An example showing how to use the display manager with a GLCd and a touch interface to create a full HMI.
Display Manager Demo
CheckForTouch
CheckForTouch
Uses the X and Y coordinates from a touch sensor to check for Widget presses. Returns 0 for no Widgets pressed. Returns ID for a valid Widget press. Any touched slider Widgets will automatically move their thumb and value to the touch position.
- UINT X
- UINT Y
ClearAll
ClearAll
Removes all objects and Widgets from memory. Also clears the screen if required.
- BOOL ClearScreen
0=Don't clear the screen, 1=Clear the screen
CreateObject
CreateObject
Define a none touchable graphical object. Returns the Object ID.
- BYTE ObjectType
0=Hidden, 1=Rect, 2=Line, 3=Ellipse, 4=FilledEllipse, 5=FilledRect
- UINT X
X Pixel Coordinate
- UINT Y
Y Pixel Coordinate
- UINT Width
Pixel Width or X Radius
- UINT Height
Pixel Height or Y Radius
- BYTE ObjectTheme
Theme index to use to draw the object
- BOOL DrawObject
0=Do not draw object yet, 1=Draw object now (Does not apply to hidden objects)
CreateTextField
CreateTextField
Creates a text field consisting of a rectangular border containing a single line of text
- STRING Text
Text string to set as the label
- UINT X
X Pixel Coordinate
- UINT Y
Y Pixel Coordinate
- UINT Width
Pixel Width
- UINT Height
Pixel Height
- BYTE Font
GLCD Font Index to use
- BYTE ObjectTheme
- BYTE HAlignment
0=Left, 1=Center, 2=Right
- BYTE VAlignment
0=Top, 1=Middle, 2=Bottom
- BOOL Transparent
0=Background Colour Drawn, 1=Don't Draw Background Colour
CreateWidget
CreateWidget
Define an interactive Widget or slider. Returns the Widget ID.
- BYTE WidgetType
0=WidgetHidden, 1=WidgetRect, 2=WidgetRoundedRect, 3=WidgetEllipse, 4=VSlider, 5=HSlider, 6=VSliderRound, 7=HSliderRound
- UINT X
X Pixel Coordinate
- UINT Y
Y Pixel Coordinate
- UINT Width
- UINT Height
- BYTE WidgetTheme
Theme index to use to draw the Widget
- BOOL DrawWidget
0=Do not draw Widget yet, 1=Draw Widget now (Does not apply to hidden widgets)
DrawAll
DrawAll
Redraws all of the defined Objects and Widgets. Doesn't draw text, this is done using the SetText macro.
DrawItem
DrawItem
Draws a single object or Widget onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro.
- UINT ID
Unique ID of the Object or Widget
GetLastTouchID
GetLastTouchID
Gets the ID of the last Widget that returned a valid press via the CheckForTouch macro. Returns 0 for no valid touch recorded.
- INT Return
GetSliderValue
GetSliderValue
Reads the value of one of the sliders ranging between 0 and 1.
- UINT WidgetID
- FLOAT Return
Initialises the object and Widget control variables and sets up the default themes.
ModifyPosition
ModifyPosition
Moves an existing object or Widget to absolute coordinates on the screen.
- UINT ID
Unique ID of the object or Widget
- INT X
- INT Y
- BOOL Relative
0=Absolute Positioning, 1=Relative Positioning
ModifyScale
ModifyScale
Changes the width and height of the selected Object or Widget.
- UINT ID
- UINT Width
- UINT Height
ModifyTheme
ModifyTheme
Changes the theme index of the selected Object or Widget.
- UINT ID
- BYTE Theme
Theme index of the Widget or object
NoTouch
NoTouch
Called when no touch is present, Allows the repeat rate counter to be cleared allowing for better responses to fast touches.
OverrideObjectTheme
OverrideObjectTheme
Overrides the colour of an object theme, used by the draw object macro.
- BYTE ThemeIndex
Index of the object colour theme
- BYTE FG_R
Foreground colour channel value
- BYTE FG_G
- BYTE FG_B
- BYTE BG_R
Background colour channel value
- BYTE BG_G
- BYTE BG_B
OverrideWidgetTheme
OverrideWidgetTheme
Overrides the colour of a Widget theme, used by the draw Widget macro.
- BYTE ThemeIndex
- BYTE FG_R
- BYTE FG_G
- BYTE FG_B
- BYTE BG_R
- BYTE BG_G
- BYTE BG_B
- BYTE HL_R
Highlight colour channel value
- BYTE HL_G
- BYTE HL_B
- BYTE LL_R
Lowlight colour channel value
- BYTE LL_G
- BYTE LL_B
SetSliderValue
SetSliderValue
Sets the value of one of the sliders and optionally redraws the slider to reflect the value change.
- UINT WidgetID
- FLOAT Value
Range: 0 to 1
- BOOL RedrawSlider
0=Do not redraw, 1=Redraw
SetTextFloat
SetTextFloat
Draws a numerical value onto an object or Widget location. Useful for displaying, value statistics. Drawn using the object themes.
- UINT ID
Unique identifier of object or Widget.
[[File:]] - Number
- BYTE NumDP
Number of decimal points to display
- STRING Unit
Unit string to add after the numeric value. e.g. "g" or "s"
- BYTE Font
- BYTE HAlignment
- BYTE VAlignment
- BYTE ObjectTheme
Object theme index to control the colour of the text
- BOOL Transparent
SetTextLabel
SetTextLabel
Draws a single line of text onto an object or Widget location. Useful for labelling Widgets such as buttons or having name, value statistics. Drawn using the object themes.
- UINT ID
- STRING Text
- BYTE Font
- BYTE HAlignment
- BYTE VAlignment
- BYTE ObjectTheme
- BOOL Transparent
SetTextNumber
SetTextNumber
- UINT ID
[[File:]] - Number
- STRING Unit
- BYTE Font
- BYTE HAlignment
- BYTE VAlignment
- BYTE ObjectTheme
- BOOL Transparent
Graphical Display
Graphical Display to draw our objects on
DM Library
Display Manager compatible GLCD library component. e.g. Bitmap drawer components.
Ram Usage Bytes
The calculated number of bytes of RAM required by the display manager.
Text Align Offset
Number of pixels to move away from an edge when calling
Objects
Max Objects
The total number of primitive objects allowed on the screen at once. Sets the size of the RAM buffers used to track the various screen elements. Each object requires 10 bytes of RAM to stores things like size, location and type.
Object Theme Count
Sets the number of themes available when drawing primitive objects. Each object theme requires 6 bytes of RAM to store the colour channels.
Object Theme 0
Foreground
Foreground colour of the theme
Background
Background colour of the theme
Object Theme 1
Foreground
Background
Object Theme 2
Foreground
Background
Widgets
Max Widgets
The total number of touchable interactibe objects allowed on the screen at once e.g. Widgets and sliders. Sets the size of the RAM buffers used to track the various screen elements Each Widget requires 18 bytes of RAM to stores things like size, location, value and type.
Touch Repeat Rate
Sets the period for touch repeats in terms of calls of the CheckForTouch macro. Widgets will only register a repeat touch after x calls if continually held down. Sliders will always register a touch. The touch count can be cleared using the NoTouch macro if no touch is detected.
Slider Thumb Width
Number of pixels wide to make a slider thumb marker,
Slider Center Line Thickness
Number of pixels thick to draw the slider central line
Widget Theme Count
Sets the number of themes available for drawng Widgets. Each Widget theme requires 12 bytes of RAM to store the colour channels.
Widget Theme 0
Foreground
Background
Highlight
Highlight colour of the theme
Lowlight
Lowlight colour of the theme
Widget Theme 1
Foreground
Background
Highlight
Lowlight
