Component: PIR Motion (Grove 101020020) (101020020) (Light)
Revision as of 10:29, 18 September 2024 by MartinW (talk | contribs) (→Examples)
Category Light
PIR Motion (Grove 101020020) component
PIR motion sensor component for digital output sensors. Simulates range sensitivity and output hold.
Please click here to download the component source project: FC_Comp_Source_PIR_Motion_Sensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PIR_Motion_Sensor.fcfx
A simple example that shows the PIR in action.
PIR Example
Configures the I/O ready for the sensor to be sampled.
SampleSensor
SampleSensor
Returns the state of the sensor. Activated if movement detected in the sensor range.
SIG Pin
Pin connected to the sensor element of the photo transistor
Sim Mode
Panel Settings
Sensitivity
Simulation range used to detect object
Holding Count
Number of calls to SampleSensor to repeat active state, once triggered
