Component: Range Time of Flight (VL53L0X) (Light)
Revision as of 08:04, 23 September 2024 by MartinW (talk | contribs) (→Examples)
Author MatrixTSL
Category Light
Range Time of Flight (VL53L0X) component
A laser based range sensor designed to provide accurate range infomation for a very narrow sensing beam. Capable of sensing ranges from 50mm to 1200mm. Communication with the device is based on a I2C bus.
ChangeI2CAddress
ChangeI2CAddress
Updates the I2C address of the sensor.
- BYTE Address
- BOOL UpdateAddressReg
0=Leave address register alone, 1=Update address register
- BOOL Return
ReadDistance
ReadDistance
Read the current distance in mm. Returns -1 if the sensor timed out during the read operation.
- INT Return
ReadModel
ReadModel
Collects the model number from the sensor
ReadRegister
ReadRegister
A simple example showing a generic way to read a register using I2C.
- BYTE Address
ReadRegister16
ReadRegister16
- BYTE Address
ReadRevision
ReadRevision
Collects the revision number from the sensor
WriteRegister
WriteRegister
A simple example showing a generic way to write a register using I2C.
- BYTE Address
- BYTE Data
WriteRegister16
WriteRegister16
- BYTE Address
- UINT Data
Sensor Properties
Range
I2C Properties
Channel selection
Baud Select
Baud rate to be used
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_RangeTOF_VL53L0X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RangeTOF_VL53L0X.fcfx
