Component: TCP/IP (ENC28J60) (Comms: Networking)
Revision as of 13:18, 10 October 2024 by MartinW (talk | contribs) (→Examples)
Version 2.2
Category Comms: Networking
TCP/IP (ENC28J60) component
A set of routines used to control a ENC28J60 TCP/IP Module. Required connections VCC, Reset, GND, SCK, MISO, MOSI, CS. Leave these pins disconnected CLKOUT, ENC_WOL, ENC_INT
Please click here to download the component source project: FC_Comp_Source_TCPIP_ENC28J60.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_ENC28J60.fcfx
Here is a simple example to help get started with the ENC28J60 module.
The example program creates a web page server on the network and will also respond to ping requests.
The HTML to drive the web pages is included in the flowchart near the bottom of the main program loop. ENC28J60 Example
CheckArpPacketIsMyreplyArp
CheckForARP
CheckForARP
Checks to see if the received data is an ARP request with my IP address.
- UINT Length
CheckForIp
CheckForIp
Checks to see if the received data is an IP request with my IP address.
- UINT Length
CheckForPing
CheckForPing
Checks to see if the received data is a Ping request
CheckForTCPPort
CheckForTCPPort
Checks to see if the received data is requesting the server port
- UINT Port
CheckForTCPType
CheckForTCPType
Checks to what kind of TCP type the received data is requesting. Returns a bit field specifying the type of request. 0x01 = Ack Requires, 0x02 = Synchronise 0x10 = Ack
ClientSendPacket
ClientSendPacket
- UINT DestPort
- UINT SourcePort
- BYTE Flags
- BYTE MaxSegmentSize
- BYTE ClearSeqAck
- UINT NextAckNum
- UINT DataLength
- BYTE DestMac
- BYTE DestIp
ControlLEDs
ControlLEDs
Allows both the LEDs on the Ethernet socket to be controlled. Useful for checking if the SPI communications are functioning correctly.
- BYTE Mode
0=Off, 1=On, 2=Auto
FillTcpArray
FillTcpArray
- UINT Position
- UINT Count
- BYTE Data
FillTcpData
FillTcpData
- UINT Position
- STRING Data
GetDataLength
GetDataLength
Returns the number of received data bytes after the headers
GetModuleRevision
GetModuleRevision
Requets the module revision number and returns the value supplied by the module's firmware.
GetSendersMAC
GetSendersMAC
Gets the MAC address from locations 6-11 of the IP Header
- BYTE MAC
6-byte Array to store the MAC address
GetTcpDataPointer
GetTcpDataPointer
Initialises the SPI connection to the TCPIP module and sets up some initial values. Flashes the LEDs on and off twice to confirm SPI comms are active. LEDs are then configured to auto functionality.
InitialiseDataLengthInfo
Initialises the data pointers to allow us to craft a response containing data
MakeArpAnswerFromRequest
MakeArpRequest
MakeArpRequest
- BYTE ServerIP
MakeEchoReplyFromRequest
- UINT Length
MakeTcpAckFromAny
MakeTcpAckFromAny
- UINT Port
MakeTcpAckWithData
MakeTcpAckWithData
- UINT DataLength
MakeTcpSynackFromSyn
- UINT Port
PacketReceive
PacketReceive
Attempts to receive a data packet from the ENC28J60 module. Returns the number of bytes received.
PacketSend
PacketSend
Attempts to transmit a data packet to the ENC28J60 module.
- UINT Length
ReadArrayFromBuffer
ReadArrayFromBuffer
Reads an array of bytes from the buffer at location specified for the number of bytes specified. If a space character is encountered then the macro will return straight away without the space character in the string.
- UINT BufferLocation
- BYTE NumberOfBytes
Number of bytes to read from the buffer and store into string
- BYTE Data
ReadRegister
ReadRegister
Reads the value from a single register onboard the ENC28J60 module.
- BYTE Address
ReadStringFromBuffer
Reads a string from the buffer at location specified for the number of bytes specified. If a space character is encountered then the macro will return straight away without the space character in the string.
- STRING Return
SetMyIPAddress
SetMyIPAddress
Allows the IP Address specified in the component properties to be overridden. The IP Address will revert back to the IP specified in the component properties as part of the initialise macro.
- BYTE IP0
IP Address Parameter - e.g. 192
- BYTE IP1
IP Address Parameter - e.g. 168
- BYTE IP2
- BYTE IP3
IP Address Parameter - e.g. 250
SetMyMACAddress
SetMyMACAddress
Allows the MAC Address specified in the component properties to be overridden. The MAC Address will revert back to the MAC specified in the component properties as part of the initialise macro.
- BYTE MAC0
MAC Address Parameter
- BYTE MAC1
- BYTE MAC2
- BYTE MAC3
- BYTE MAC4
- BYTE MAC5
WriteRegister
WriteRegister
Writes a value to a single register onboard the ENC28J60 module.
- BYTE Address
- BYTE Data
TCP IP Specifics
Server Port
Sets the server's TCP/IP port address which is used to filter incoming TCP packets.
Buffer Size
Number of bytes to use for the transmit and receive buffer, we actually use this +1 to allow for a null termination. 8-bit PICs should set this to 255 to allow compilation to succeed. Other devices can have larger buffers. Default = 500
SPI Settings
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Reset Pin
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
IP Address
IP0
IP1
IP2
IP3
Sim Type
Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / API - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
SPI Simulation
API
