Remappable Pin Table
This "Remappable Pin Table" wiki page provides pin mappings and functionality for various microcontrollers and development boards, allowing users to understand the input/output pin assignments and specific features available on each.
Arduino Uno
Lists pin numbers and corresponding port bit, functions like analog input, power, ground, reset, USART (serial communication), SPI (serial peripheral interface), I2C (inter-integrated circuit), external interrupts, and PWM (pulse-width modulation). Detailed breakdown of pin configurations for specific functions like communication protocols and control signals.
| Pin no | Port | Bit | Power | GND | Analog | Xtal | Osc | RESET | USART | SPI | I2C | INT | PCINT | PWM | Arduino Ref. |
| 1 | C | 6 | !RESET | PCINT14 | |||||||||||
| 2 | D | 0 | RXD | PCINT16 | 0 | ||||||||||
| 3 | D | 1 | TXD | PCINT17 | 1 | ||||||||||
| 4 | D | 2 | INT0 | PCINT18 | 2 | ||||||||||
| 5 | D | 3 | INT1 | PCINT19 | PWM | 3 | |||||||||
| 6 | D | 4 | PCINT20 | 4 | |||||||||||
| 7 | VCC | ||||||||||||||
| 8 | GND | ||||||||||||||
| 9 | XTAL1 | TOSC1 | PCINT6 | ||||||||||||
| 10 | XTAL2 | TOSC2 | PCINT7 | ||||||||||||
| 11 | D | 5 | PCINT21 | PWM | 5 | ||||||||||
| 12 | D | 6 | PCINT22 | PWM | 6 | ||||||||||
| 13 | D | 7 | PCINT23 | 7 | |||||||||||
| 14 | B | 0 | PCINT0 | 8 | |||||||||||
| 15 | B | 1 | PCINT1 | PWM | 9 | ||||||||||
| 16 | B | 2 | SS | PCINT2 | PWM | 10 | |||||||||
| 17 | B | 3 | MOSI | PCINT3 | PWM | 11 | |||||||||
| 18 | B | 4 | MISO | PCINT4 | 12 | ||||||||||
| 19 | B | 5 | SCK | PCINT5 | 13 | ||||||||||
| 20 | AVCC | ||||||||||||||
| 21 | |||||||||||||||
| 22 | GND | ||||||||||||||
| 23 | C | 0 | ADC0 | PCINT8 | 14 | ||||||||||
| 24 | C | 1 | ADC1 | PCINT9 | 15 | ||||||||||
| 25 | C | 2 | ADC2 | PCINT10 | 16 | ||||||||||
| 26 | C | 3 | ADC3 | PCINT11 | 17 | ||||||||||
| 27 | C | 4 | ADC4 | SCL | PCINT12 | 18 | |||||||||
| 28 | C | 5 | ADC5 | SDA | PCINT13 | 19 |
PIC16F18877
Provides pin details for this Microchip PIC microcontroller, including ports, ADC (analog-to-digital conversion) channels, external clock pins, reset, USART, SPI, I2C, interrupts, PWM, and other input/output control options. Emphasis on different analog input capabilities and communication protocol interfaces.
| Pin no | Port | Bit | Power | GND | ADC | Xtal | Osc | RESET | USART | SPI | I2C | INT | PCINT | PWM |
| 1 | E | 3 | VPP | !MCLR | IOCE3 | |||||||||
| 2 | A | 0 | ANA0 | IOCA0 | ||||||||||
| 3 | A | 1 | ANA1 | IOCA1 | ||||||||||
| 4 | A | 2 | ANA2 | IOCA2 | ||||||||||
| 5 | A | 3 | ANA3 | IOCA3 | ||||||||||
| 6 | A | 4 | ANA4 | IOCA4 | CCP5 | |||||||||
| 7 | A | 5 | ANA5 | SS1 | IOCA5 | |||||||||
| 8 | E | 0 | ANE0 | |||||||||||
| 9 | E | 1 | ANE1 | |||||||||||
| 10 | E | 2 | ANE2 | |||||||||||
| 11 | VDD | |||||||||||||
| 12 | VSS | |||||||||||||
| 13 | A | 7 | ANA7 | OSC1/CLKIN | IOCA7 | |||||||||
| 14 | A | 6 | ANA6 | OSC2/CLKOUT | IOCA6 | |||||||||
| 15 | C | 0 | ANC0 | SOSCO | ||||||||||
| 16 | C | 1 | ANC1 | SOSCI | IOCC1 | CCP2 | ||||||||
| 17 | C | 2 | ANC2 | IOCC2 | CCP1 | |||||||||
| 18 | C | 3 | ANC3 | SCL1/SCK1 | IOCC3 | |||||||||
| 19 | D | 0 | AND0 | SDA1/SDI1 | IOCC4 | |||||||||
| 20 | D | 1 | AND1 | IOCC5 | ||||||||||
| 21 | D | 2 | AND2 | IOCC6 | ||||||||||
| 22 | D | 3 | AND3 | IOCC7 | ||||||||||
| 23 | C | 4 | ANC4 | |||||||||||
| 24 | C | 5 | ANC5 | |||||||||||
| 25 | C | 6 | ANC6 | CK | ||||||||||
| 26 | C | 7 | ANC7 | RX/DT | ||||||||||
| 27 | D | 4 | AND4 | |||||||||||
| 28 | D | 5 | AND5 | |||||||||||
| 29 | D | 6 | AND6 | |||||||||||
| 30 | D | 7 | AND7 | |||||||||||
| 31 | VSS | |||||||||||||
| 32 | VDD | |||||||||||||
| 33 | B | 0 | ANB0 | SS2 | IOCB0 | CCP4 | ||||||||
| 34 | B | 1 | ANB1 | SCLK2 | IOCB1 | |||||||||
| 35 | B | 2 | ANB2 | SDA2 | IOCB2 | |||||||||
| 36 | B | 3 | ANB3 | IOCB3 | ||||||||||
| 37 | B | 4 | ANB4 | IOCB4 | ||||||||||
| 38 | B | 5 | ANB5 | IOCB5 | CCP3 | |||||||||
| 39 | B | 6 | ANB6 | ICSPCLK | IOCB6 | |||||||||
| 40 | B | 7 | ANB7 | ICSPDAT | IOCB7 |
ESP32 Lolin DOWDQ6
Describes pin assignments for ADC (analog-to-digital converter), PWM, GPIO (general-purpose input/output), reset, USART, SPI, and I2C for the ESP32 board. Lists pin mappings relevant to power management and interfacing with external devices.
| Pin no | Port | Bit | Power | GND | ADC | Xtal | Osc | RESET | USART | SPI | I2C | INT | PCINT | PWM | Mfr. Ref. |
| 1 | B | 4 | ADC1_0 | GPIO36 | |||||||||||
| 2 | B | 7 | ADC1_3 | GPIO39 | |||||||||||
| 3 | !RESET | ||||||||||||||
| 4 | B | 2 | ADC1_6 | GPIO34 | |||||||||||
| 5 | B | 3 | ADC1_7 | GPIO35 | |||||||||||
| 6 | B | 0 | ADC1_4 | XTAL32N | PWM | GPIO32 | |||||||||
| 7 | B | 1 | ADC1_5 | XTAL32P | PWM | GPIO33 | |||||||||
| 8 | A | 25 | ADC2_8 | PWM | GPIO25 | ||||||||||
| 9 | A | 26 | ADC2_9 | PWM | GPIO26 | ||||||||||
| 10 | A | 27 | ADC2_7 | PWM | GPIO27 | ||||||||||
| 11 | A | 14 | ADC2_6 | PWM | GPIO14 | ||||||||||
| 12 | A | 12 | ADC2_5 | PWM | GPIO12 | ||||||||||
| 13 | GND | ||||||||||||||
| 14 | A | 13 | ADC2_4 | PWM | GPIO13 | ||||||||||
| 15 | A | 15 | ADC2_3 | PWM | GPIO15 | ||||||||||
| 16 | A | 2 | ADC2_2 | PWM | GPIO2 | ||||||||||
| 17 | A | 0 | ADC2_1 | PWM | GPIO0 | ||||||||||
| 18 | A | 4 | ADC2_0 | PWM | GPIO4 | ||||||||||
| 19 | A | 16 | RX | PWM | GPIO16 | ||||||||||
| 20 | A | 17 | TX | PWM | GPIO17 | ||||||||||
| 21 | A | 15 | SS | PWM | GPIO15 | ||||||||||
| 22 | A | 18 | CLK | PWM | GPIO18 | ||||||||||
| 23 | A | 23 | MOSI | PWM | GPIO23 | ||||||||||
| 24 | A | 19 | CTS 0 | MISO | PWM | GPIO19 | |||||||||
| 25 | A | 22 | RTS 0 | SCL | PWM | GPIO22 | |||||||||
| 26 | 3V3 |
Matrix EBlocks Combo Board
Shows port and bit configurations for various onboard features such as LEDs, switches, 7-segment displays, LCD screens, and analog sound outputs. Highlights control over integrated components through the board's ports.
| E-blocks connections | ||||||||
| Port | bit | LED 1 | Switch 2 | 7-seg | LCD | An | Sound | |
| 1 | 0 | 0 | DP | Light | ||||
| 1 | 1 | 1 | Com0 | pot | ||||
| 1 | 2 | 2 | Com1 | |||||
| 1 | 3 | 3 | Com2 | |||||
| 1 | 4 | 4 | Com3 | |||||
| 1 | 5 | 5 | ||||||
| 1 | 6 | 6 | ||||||
| 1 | 7 | 7 | ||||||
| 2 | 0 | 0 | A | Data0 | ||||
| 2 | 1 | 1 | B | Data1 | ||||
| 2 | 2 | 2 | C | Data2 | OutL | |||
| 2 | 3 | 3 | D | Data3 | OutR | |||
| 2 | 4 | 4 | E | RS | ||||
| 2 | 5 | 5 | F | Enable | ||||
| 2 | 6 | 6 | G | |||||
| 2 | 7 | 7 | H |
Matrix EBlocks Motor Board
| Port | bit | Servo | |
| 1 | 0 | 0 | |
| 1 | 1 | ||
| 1 | 2 | ||
| 1 | 3 | ||
| 1 | 4 | ||
| 1 | 5 | ||
| 1 | 6 | ||
| 1 | 7 |
