Component: Actuators (BL0127) (E-blocks 2)
Revision as of 08:58, 9 June 2025 by Wiki bot (talk | contribs)
Category E-blocks 2
Actuators component
The Actuators board allows for investigation into several different motor types. Included on the board is a DC motor with both analogue and digital feedback, a servo motor and a stepper motor plus the circuitry to drive the motors.
Version information
Demo program using the Eblocks 2 Actuators Board BL0127 connected to BL0011 PIC programmer FC6 Icon.png BL0127 Actuators Demo for PIC
DCMotor_Break
Fc9-comp-macro.png DCMotor_Break
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
DCMotor_Coast
Fc9-comp-macro.png DCMotor_Coast
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
DCMotor_DC_Feedback
Fc9-comp-macro.png DCMotor_DC_Feedback
DCMotor_DC_FeedbackSim
Fc9-comp-macro.png DCMotor_DC_FeedbackSim
DCMotor_Disable
Fc9-comp-macro.png DCMotor_Disable
Disable the motor output
DCMotor_Enable
Fc9-comp-macro.png DCMotor_Enable
Enables the motor output
DCMotor_Forwards
Fc9-comp-macro.png DCMotor_Forwards
Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property.
Fc9-u16-icon.png - UINT Duty
Sets the motor power for PWM or H-Bridge outputs
DCMotor_Reverse
Fc9-comp-macro.png DCMotor_Reverse
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
Servo_AutoMoveToPosition
Fc9-comp-macro.png Servo_AutoMoveToPosition
Automatically moves towards the new position at a fixed rate determined by the AutoMoveSpeed.
The channel to assign the new position. Range: 0-7
Fc9-u8-icon.png - BYTE Position
Position to automatically move to. Range: 0-255
Servo_AutoMoveToPositionInt
Fc9-comp-macro.png Servo_AutoMoveToPositionInt
Automatically moves towards the new 16-bit position at a fixed rate determined by the AutoMoveSpeed.
Fc9-u16-icon.png - UINT Position
Position to automatically move to. Range: 0-65535
Servo_DisableServo
Fc9-comp-macro.png Servo_DisableServo
Disables a servo channel effectivly disabling the motor.
The channel to set the position for. First channel is zero.
Servo_EnableServo
Fc9-comp-macro.png Servo_EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
Servo_Initialise
Fc9-comp-macro.png Servo_Initialise
Sets up the servo motor interrupts
Servo_IsAutoMoving
Fc9-comp-macro.png Servo_IsAutoMoving
Is the AutoMoveToPosition movement complete. Returns 1 if the servos are still moving. Returns 0 if all servo movement is complete.
Servo_IsServoAutoMoving
Fc9-comp-macro.png Servo_IsServoAutoMoving
Is the AutoMoveToPosition movement complete for a specific servo output. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
Servo Motor Output Range: 0-7
Servo_MoveToPosition
Fc9-comp-macro.png Servo_MoveToPosition
Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
Target position to move towards. Range: 0-255
Servo_MoveToPositionInt
Fc9-comp-macro.png Servo_MoveToPositionInt
Target position to move towards. Range: 0-65535
Servo_SetAutoMoveSpeed
Fc9-comp-macro.png Servo_SetAutoMoveSpeed
Sets the speed of the auto move to position macro. Default speed is shown in the Servo_Period_Multiplier property.
Fc9-u8-icon.png - BYTE Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
Servo_SetAutoMoveSpeedInt
Fc9-comp-macro.png Servo_SetAutoMoveSpeedInt
Fc9-u16-icon.png - UINT Speed
Servo_SetPosition
Fc9-comp-macro.png Servo_SetPosition
Moves directly to the specified position with no interpolation.
Position to jump to. Range: 0-255
Servo_SetPositionInt
Fc9-comp-macro.png Servo_SetPositionInt
Moves directly to the specified position with no interpolation. Uses a 16-bit position parameter to add extra precision.
Position to jump to. Range: 0-65535
Servo_SetTrim
Fc9-comp-macro.png Servo_SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
Fc9-u8-icon.png - BYTE Trim
Legacy: 0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us or Smooth: 0-200
Stepper_DecrementStep
Fc9-comp-macro.png Stepper_DecrementStep
Move the motor backwards by one step.
Stepper_DisableMotor
Fc9-comp-macro.png Stepper_DisableMotor
Turn off the motor. It will no longer respond to any other macros.
Stepper_EnableMotor
Fc9-comp-macro.png Stepper_EnableMotor
Turn on the motor. This must be done before it will respond to any other macros.
Stepper_IncrementStep
Fc9-comp-macro.png Stepper_IncrementStep
Move the motor forward by one step.
Fc9-type-16-icon.png Connection Type
Fc9-type-16-icon.png DC Feedback type
Select if the feedback is a digital or analogue value. Note, if using an Arduino shield and port D is selected, then only digital type will be available.
Fc9-type-19-icon.png Port
Port C is not available on the Arduino shield, If port C is slected, it will default to port B.
Fc9-conn-icon.png Servo
Fc9-conn-icon.png Trim
Fc9-conn-icon.png Pulse Width
Fc9-type-21-icon.png Minimum (us)
Shortest pulse width that will be used in microseconds.
Fc9-type-21-icon.png Maximum (us)
Longest pulse width used for the PWM signals in microseconds..
Fc9-type-21-icon.png Period Multiplier
Number of instructions for 1 / 256th of the positional accuracy. This sets the default movement speed to maintain legacy move speeds. Also sets the multiplication factor to convert from a byte 0-255 to a clocked position value.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
