Component: ADC ADS1256 (Analog Input)
Revision as of 08:58, 9 June 2025 by Wiki bot (talk | contribs)
Category Analog Input
ADC ADS1256 component
24-bit very low noise single ended or differential ADC compatible with ADS1255 or ADS1256. ADS1255 has two single ended or one differential input. ADC1256 has eight single ended or four differential inputs.
Version information
7, 1.0, 25-10-24, BR, Minor change to try and address a problem
8, 1.0, 28-10-24, BR, Solved a problem where the sensor didn't init correctly
Fc9-comp-macro.png Initialise
Sets up the SPI bus ready for communications with the sensor IC.
ReadData
Fc9-comp-macro.png ReadData
Reads the result of an ADC conversion as a binary value in the range of 0 to 16,777,215
ReadDataAsVoltage
Fc9-comp-macro.png ReadDataAsVoltage
Reads the result of an ADC conversion as a floating point voltage
ReadIO
Fc9-comp-macro.png ReadIO
Reads from the general purpose IO pins
Fc9-u8-icon.png - BYTE Mask
Range: 0 (0b0000) to 15 (0b1111)
SetupADC
Fc9-comp-macro.png SetupADC
Configures the positive and negative input channels
Fc9-u8-icon.png - BYTE PositiveChannel
0=AIN0 - 7=AIN7, 8=AINCOM
Fc9-u8-icon.png - BYTE NegativeChannel
Fc9-u8-icon.png - BYTE Gain
0=1X, 1=2X, 2=4X, 3=8X, 4=16X, 5=32X, 6=64X
WriteIO
Fc9-comp-macro.png WriteIO
Writes to the general purpose IO pins
Fc9-u8-icon.png - BYTE Value
Fc9-type-16-icon.png Type
Fc9-type-15-icon.png VREF Voltage
Voltage reference used in the calculations for ReadDataAsVoltage
Fc9-type-16-icon.png Data Rate
Specified the data rate in samples per second. Based on a clock rate of 7.68MHz and scales linearly with fCLKIN
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-5-icon.png CS / SS
Fc9-type-5-icon.png Data Ready
Fc9-type-5-icon.png Sync
Fc9-conn-icon.png Simulation
Please click here to download the component source project: FC_Comp_Source_ExternalADC_ADS1256.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ExternalADC_ADS1256.fcfx
