Component: Temp / Humidity (SHT21) (Environmental)
Revision as of 08:59, 9 June 2025 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temp / Humidity (SHT21) component
Humidity and temperature sensor using an SHT21 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
GetHumidityInt
GetHumidityInt
returns the relative Humidity reading as an integer value
- INT Return
GetHumidityReal
GetHumidityReal
returns the Humidity reading as a float value
- FLOAT Return
GetTemperatureInt
GetTemperatureInt
Return temperature reading as an integer value in degrees C
- INT Return
GetTemperatureReal
GetTemperatureReal
Return temperature reading as a float value in degrees C
- FLOAT Return
Initialises the component ready for I2C communications
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Baud Select
Baud rate to be used
Stop Delay
Simulation Comms
Please click here to download the component source project: FC_Comp_Source_Humidity_SHT21.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_SHT21.fcfx
