Component: LoRaWAN (Seeed WIO-E5) (LORAWAN-E5) (Comms: IoT/Cloud)
Revision as of 21:24, 9 June 2025 by Kersing (talk | contribs)
Author Jac Kersing
Category Comms: IoT/Cloud
LoRaWAN (Seeed WIO-E5) component
LoRaWAN Component for the Seeed WIO-E5 module.
LoraWAN Demo
Example LoRaWAN demo file.
LoRaWAN Demo
ChkConnected
ChkConnected
Sends AT command and checks response to check the LoRa E5 module is connected to the controller.
- INT Return
FreeUart
FreeUart
Release UART resources (to allow for sleeping on some microcontrollers)
GetDownlinkByte
GetDownlinkByte
Get one byte from the received downlink message, returns -1 if no more bytes are available.
- INT Return
GetId
GetId
Get the specified ID from the LoRaWAN module. Valid types are DevEUI, AppEUI and DevAddr
- STRING type
- STRING Return
GetPort
GetPort
Get the portnumber of the downlink message.
GotDownlink
Was a downlink received?
- BOOL Return
Initialize
Initialize
Initialize the component. Should be called before any other function is used but after the component received a hardware reset. (Toggle of the reset pin)
Join
Join
Execute a join command to have the module join the LoRaWAN network. Returns 1 on a successfull join, 0 if the join failed. Keep in mind there is no interaction with the LoRaWAN network if Join mode is ABP so it will always succeed if all parameters have been initialized correctly. In Join mode OTAA a join will fail if the module does not get a valid response from teh network which may occur if the DevEUI, AppEUI or AppKey are not correct or if there is no coverage at the location.
LowPowerSleep
LowPowerSleep
Set low power sleep mode. Specify the number of seconds to sleep in the range 6-12959.
- INT seconds
ReInitUart
ReInitUart
Reclaim the UART after low power sleep of the CONTROLLER (not the LoRaWAN module).
SendMsg
SendMsg
Send LoRaWAN message, the message should be an array of byte values. To conserve airtime no ASCII strings should be used.
- BYTE msg
- BYTE len
SendMsgConfirmed
SendMsgConfirmed
Send a confirmed LoRaWAN message, the message should be an array of byte values. To conserve airtime no ASCII strings should be used. Use confirmed messages sparingly as transmitting gateways can normally receive 8 parallel messages but not 1 message while transmitting. So it kills scalebility of a LoRaWAN network!
- BYTE msg
- BYTE len
SetDr
SetDr
Explicitly set DataRate of transmissions. Valid values depend on the region used please consult the LoRaWAN regional parameter document to find them.
- BYTE dr
SetId
SetId
Set an ID. Valid options are "AppEUI", "DevEUI" and "DevAddr". The value to use is an 16 HEX character long string for EUIs or a 8 HEX characters long string for DevAddr. Examples: AppEUI: "001122334455AABB" DevAddr: "001122AA"
- STRING type
- STRING value
SetJoinMode
SetJoinMode
Set the join mode, valid options are MODE_OTAA or MODE_ABP.
- STRING mode
SetKey
SetKey
Set encryption key. Valid key types are: "APPKEY", "APPSKEY" and "NWKSKEY". For OTAA only APPKEY is required. For ABP both APPSKEY and NWKSKEY are required. The value shoud be a 32 HEX character string. Example value: "00112233445566778899AABBCCDDEEFF"
- STRING type
- STRING value
SetLowPower
SetLowPower
Set the Low Power mode of the module. Low power can be off (false) or on (true)
- BOOL on
SetPort
SetPort
Set the port used for transmissions
- BYTE port
SetRegion
SetRegion
Set the LoRaWAN region to be used. For US915 the band (of 8 channels) to be used needs to be specified as well, the band is ignored for EU868 TTN uses band 1 in US915.
- STRING region
- BYTE band
LoRaWAN settings
Max Downlink Size
Sets the number of byte elements inside the circular buffer.
Baud Options
TX
TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
API
Selects which API component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
Please click here to download the component source project: FC_Comp_Source_lora-e5-component.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_lora-e5-component.fcfx
