Component: Rectangle (Graphical Manager Primitives)
Revision as of 14:13, 22 October 2025 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Graphical Manager Primitives
Rectangle component
A rectangle primitive used with the Graphical Manager on the GLCD Layout Editor panel.
GetID
Fc9-comp-macro.png GetID
Returns the assigned object/widget ID.
ModifyColour
Fc9-comp-macro.png ModifyColour
Changes the theme index of the selected Object or Widget.
Fc9-u8-icon.png - BYTE Index
0=Foreground, 1=Background, 2=Text, 3=Highlight
Fc9-u8-icon.png - BYTE R
Fc9-u8-icon.png - BYTE G
Fc9-u8-icon.png - BYTE B
Fc9-bool-icon.png - BOOL Redraw
ModifyPosition
Fc9-comp-macro.png ModifyPosition
Moves an existing object or Widget to absolute coordinates on the screen.
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-bool-icon.png - BOOL Relative
0=Absolute Positioning, 1=Relative Positioning
ModifyScale
Fc9-comp-macro.png ModifyScale
Changes the width and height of the selected Object or Widget.
Fc9-u16-icon.png - UINT Width
Fc9-u16-icon.png - UINT Height
SetTextFloat
Fc9-comp-macro.png SetTextFloat
Draws a floating point value with optional units onto an object or Widget location.
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE NumDP
Number of decimal points to display
Fc9-string-icon.png - STRING Unit
Optional unit string to add after the numeric value. e.g. "g" or "s"
SetTextLabel
Fc9-comp-macro.png SetTextLabel
Draws a string onto an object or Widget location.
Text string to set as the label
SetTextNumber
Fc9-comp-macro.png SetTextNumber
Draws an integer numerical value with optional units onto an object or Widget location.
Fc9-s16-icon.png - INT Number
Unit string to add after the numeric value. e.g. "g" or "s"
Fc9-conn-icon.png Appearance
Fc9-type-21-icon.png Line Width
Width of the outer border line in pixels
Fc9-type-1-icon.png Line Colour
The colour of the outer border line
Fc9-type-1-icon.png Fill Colour
The fill colour of the shape
Fc9-conn-icon.png Touch
Fc9-type-7-icon.png Touchable
Determines if the display creator defined area responds to touches Touch is detected by using the DisplayManager::CheckForTouch macro with the X,Y coordinates of a touch
Fc9-conn-icon.png Text
Fc9-type-10-icon.png Text
Optional default text to add to the inside of the shape
Fc9-type-16-icon.png Font
GLCD font to use
Fc9-type-16-icon.png Horizontal Alignment
Horizontal alignment of the text label inside the shape
Fc9-type-16-icon.png Vertical Alignment
Vertical alignment of the text label inside the shape
Fc9-type-1-icon.png Text Colour
The colour of the text
Please click here to download the component source project: FC_Comp_Source_DC_Rectangle.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DC_Rectangle.fcfx
