Component: Temperature (TMP117) (Environmental)
Revision as of 14:13, 22 October 2025 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Environmental
Temperature (TMP117) component
The TMP117 provides high accuracy temperature monitoring via a digital I2C interface.
A basic example which moves an object on the panel. When the object is in range of the sensor the sensor output goes high, otherwise the sensor output goes low. FC6 Icon.png PhotoTransistorDemo
Fc9-comp-macro.png Initialise
Sets up the I2C ready for operation and initialises the sensor with the default settings. Returns 1 if the device is correctly identified.
ReadRegister
Fc9-comp-macro.png ReadRegister
ReadTemperature
Fc9-comp-macro.png ReadTemperature
Reads the temperature as a floating point value in Celcius.
ReadTemperatureF
Fc9-comp-macro.png ReadTemperatureF
Reads the temperature as a floating point value in Fahrenheit
SetMode
Fc9-comp-macro.png SetMode
Sets the mode of the sensor and therefore the amount of power consumed by the sensor.
Fc9-u8-icon.png - BYTE Mode
0=Shutdown, 3=Triggered, 7=Continuous
SetTemperatureOffset
Fc9-comp-macro.png SetTemperatureOffset
Allows an offset to be written to offset the output temperature
Fc9-f32-icon.png - FLOAT Offset
Temperature offset in degrees C
WriteRegister
Fc9-comp-macro.png WriteRegister
Fc9-u16-icon.png - UINT Value
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Settings
Fc9-type-16-icon.png Address A0
Sets the I2C device address based on the state of the device AD0 pin
Fc9-type-16-icon.png Default Mode
Sets the default mode of the sensor on initialise. Can be overridden using the SetMode macro.
Fc9-type-16-icon.png Standby Time
Sets the amount of time to wait between samples to save power.
Fc9-type-16-icon.png Averaging Count
Sets the number of samples used for each averaging period. Can be overridden using the SetAveragingCount macro.
Fc9-type-16-icon.png Alert Polarity
Fc9-type-16-icon.png Alert Type
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Specifies the API component on the panel to interact with to provide comms simulation.
Please click here to download the component source project: FC_Comp_Source_Temperature_TMP117.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Temperature_TMP117.fcfx
