Component: Thermistor Using Beta (Environmental)
Revision as of 14:13, 22 October 2025 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Environmental
Thermistor Using Beta component
ReadTemperature
Fc9-comp-macro.png ReadTemperature
Fc9-bool-icon.png - BOOL TempFormat
0 = Centigrade, 1 = Fahrenheit
ReadThermistorValue
Fc9-comp-macro.png ReadThermistorValue
Fc9-conn-icon.png Themistor
Fc9-type-21-icon.png Ohms Value at 25C
Thermistor resistance at 25C is usually found on the thermistor datasheet. If you have a 10K thermistor, that that will be the value at 25C
Fc9-type-21-icon.png Beta Value
Beta value is usually found on the thermistor datasheet
Fc9-conn-icon.png Fixed Resistor
Value of pullup or pulldown fixed resistor in ohms
Fc9-type-16-icon.png Resistor Biasing
Pullup - Fixed resistor is connected to + of the supply Pulldown - Fixed resistor is connected to 0V of the supply
Fc9-conn-icon.png ADC
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Temperature
Fc9-type-14-icon.png Offset x 100
+/- x100 Enter temperature offset x 100 For example, temperature measured with an accurate thermometer is 22.0. Returned is 23.4, which is 1.4 degrees too high. For offset enter -140.
Fc9-type-15-icon.png OffSet
Fc9-type-21-icon.png Result Decimal Places
Number of decimal places (0 to 4) for temperaure results
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Highest Temperature
Fc9-type-15-icon.png Lowest Temperature
Fc9-type-16-icon.png Temperature Units
Please click here to download the component source project: FC_Comp_Source_Thermistor_Using_Beta.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor_Using_Beta.fcfx
