Component: Bluetooth BLE (ESP32 SPP Client) (Wireless)
| Category | Wireless |
Bluetooth BLE (ESP32 SPP Client) component
Bluetooth BLE client component designed to run on a ESP32 providing GATT SPP functionality. Designed to scan for and connect to an existing Bluetooth BLE GATT SPP server. BT BLE functionality must be switched on via the sdkconfig file.
CheckConnectionStatus
| CheckConnectionStatus | |
| Checks to see if the Bluetooth device is connected. Returns 1 if connected. | |
ConnectToDevice
| ConnectToDevice | |
| Manually connect to the specified discovered device. Returns true if the device connected successfully. | |
| index | |
DisconnectFromDevice
| DisconnectFromDevice | |
| Manually disconnect from the connected device | |
GetDiscoveredDeviceCount
| GetDiscoveredDeviceCount | |
| Returns the number of discovered devices. | |
GetDiscoveredDeviceMAC
| GetDiscoveredDeviceMAC | |
| Gets the 6 Byte MAC address of the discovered device at the selected index | |
| index | |
| MAC | |
| 6-byte Array to return the MAC address into | |
GetDiscoveredDeviceName
| GetDiscoveredDeviceName | |
| Gets the friendly name of the discovered device at the selected index | |
| index | |
| Starts up the Bluetooth communications SPP service. | |
ReceiveArray
ReceiveByte
| ReceiveByte | |
| Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured | |
| Timeout | |
| Number of ms to wait for incoming data | |
ReceiveCount
| ReceiveCount | |
| Collects the number of bytes currently stored in the receive buffer. | |
ReceiveString
SendArray
| SendArray | |
| Sends a byte to the Bluetooth serial connection | |
| Data | |
| Data Array to send | |
| NumBytes | |
| Number of bytes to send | |
SendByte
| SendByte | |
| Data | |
SendString
| SendString | |
| Sends a string to the Bluetooth serial connection | |
| Data | |
Uninitialise
| Uninitialise | |
| Shots down the Bluetooth communications SPP service. | |
Please click here to download the component source project: FC_Comp_Source_Bluetooth_ESP32_BLE_GATT_SPP_Client.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_ESP32_BLE_GATT_SPP_Client.fcfx
