| Author
Matrix TSL
| Version
1.0
| Category
EEPROM
FRAM MB85RC component
I2C Ferroelectric Random Access Memory (FRAM) component for Fujitsu MB85RC and Cypress FM24/CY15B series devices. Supports 4K to 1M devices. Based on FRAM_MB85RC_I2C Arduino library.
DisableWriteProtect
DisableWriteProtect
| Disables write protection on the FRAM device. Returns error code: 0=success
- BYTE
EnableWriteProtect
EnableWriteProtect
| Enables write protection on the FRAM device. Returns error code: 0=success
- BYTE
EraseDevice
EraseDevice
| Erases the entire FRAM device by writing zeros to all memory locations. Returns error code: 0=success, 1-4=error
- BYTE
| Initializes the I2C interface and prepares the FRAM device for operation. Returns error code: 0=success, 1-4=error
- BYTE
Read
Read
| Reads a single byte from the specified FRAM address. Returns the byte value read, or 0xFF on error.
- ULONG
Address
| Memory address to read from
- BYTE
ReadFloat
ReadFloat
| Reads a 32-bit floating point value (FLOAT) from the specified FRAM address. Returns the float value read, or 0.0 on error.
- ULONG
Address
- FLOAT
ReadInt
ReadInt
| Reads a 16-bit signed integer (INT) from the specified FRAM address. Returns the integer value read, or 0 on error.
- ULONG
Address
- INT
ReadLong
ReadLong
| Reads a 32-bit signed integer (LONG) from the specified FRAM address. Returns the long value read, or 0 on error.
- ULONG
Address
- LONG
ReadPage
ReadPage
| Reads multiple bytes starting from the specified address. Returns number of bytes read, or 0 on error.
- ULONG
Address
| Starting memory address
- BYTE
Data
| Buffer to store read data
- UINT
Count
| Number of bytes to read
- UINT
Write
Write
| Writes a single byte to the specified FRAM address. Returns error code: 0=success, 1-4=error
- ULONG
Address
| Memory address to write to
- BYTE
Data
| Byte value to write
- BYTE
WriteFloat
WriteFloat
| Writes a 32-bit floating point value (FLOAT) to the specified FRAM address. Returns error code: 0=success, 1-4=error
- ULONG
Address
- FLOAT
Data
| Float value to write
- BYTE
WriteInt
WriteInt
| Writes a 16-bit signed integer (INT) to the specified FRAM address. Returns error code: 0=success, 1-4=error
- ULONG
Address
- INT
Data
| Integer value to write
- BYTE
WriteLong
WriteLong
| Writes a 32-bit signed integer (LONG) to the specified FRAM address. Returns error code: 0=success, 1-4=error
- ULONG
Address
- LONG
Data
| Long value to write
- BYTE
WritePage
WritePage
| Writes multiple bytes starting from the specified address. Returns number of bytes written, or 0 on error.
- ULONG
Address
- BYTE
Data
| Buffer containing data to write
- UINT
Count
| Number of bytes to write
- UINT
Device Settings
Device Address
| I2C device address bits (A2, A1, A0). Default is 0x50 (0b1010000). For 1M devices, use two component instances with addresses ending in 0 and 1.
Device Type
| Select the FRAM device type
Memory Size (bytes)
| Calculated memory size based on device type
Address Bits
| Number of address bits for selected device
| Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
| On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not a 10ms delay between an I2C stop event and the next I2C start event.
Baud Select
| Baud rate option selector
| Baud rate to be used
API
| Specifies the API component on the panel to interact with to provide comms simulation.
Please click here to download the component source project: FC_Comp_Source_FRAM_MB85RC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FRAM_MB85RC.fcfx
