Component: Matrix Cap Touch Display (Development)
| Category | Development |
- 1 Matrix Cap Touch Display component
- 2 Detailed description
- 3 Examples
- 4 Macro reference
- 4.1 BluetoothConnectionStatus
- 4.2 BluetoothInit
- 4.3 BluetoothReceiveArray
- 4.4 BluetoothSendArray
- 4.5 BluetoothUninit
- 4.6 ClearDisplay
- 4.7 DrawArc
- 4.8 DrawBitmap
- 4.9 DrawButton
- 4.10 DrawEllipse
- 4.11 DrawGraph
- 4.12 DrawLine
- 4.13 DrawPixel
- 4.14 DrawQRCode
- 4.15 DrawRectangle
- 4.16 DrawRoundedRectangle
- 4.17 DrawString
- 4.18 FileCreate
- 4.19 FileDelete
- 4.20 FileInit
- 4.21 FileOpen
- 4.22 FileReadArray
- 4.23 FileWriteArray
- 4.24 FolderOpen
- 4.25 GetAPIVersion
- 4.26 GetCardPresent
- 4.27 GetLastButtonPress
- 4.28 GetLastRawTouchCoordinate
- 4.29 GetSliderValue
- 4.30 Initialise
- 4.31 ListenForTouch
- 4.32 SetBackgroundColour
- 4.33 SetBacklightBrightness
- 4.34 SetBitmapTransparencyColour
- 4.35 SetButtonIntervalPeriod
- 4.36 SetColourPallet
- 4.37 SetFontScaler
- 4.38 SetForegroundColour
- 4.39 SetGraphData
- 4.40 SetOrientation
- 4.41 SetSliderValue
- 4.42 UpdateButtonText
- 4.43 UpdateButtonTheme
- 4.44 WifiAcceptClose
- 4.45 WifiAcceptOpen
- 4.46 WifiConnectToSSID
- 4.47 WifiCreateAccessPoint
- 4.48 WifiDisconnect
- 4.49 WifiInit
- 4.50 WifiReadIP
- 4.51 WifiReceiveArray
- 4.52 WifiScan
- 4.53 WifiScanEncryptionMode
- 4.54 WifiScanSSID
- 4.55 WifiScanSigStrength
- 4.56 WifiSendArray
- 4.57 WifiSocketClose
- 4.58 WifiSocketConnect
- 4.59 WifiSocketListen
- 4.60 WifiSocketOpen
- 4.61 WifiUninit
- 5 Property reference
- 6 Component Source Code
A component to drive the capacitive touch display module as used in EM, 3PH PSU, CNC
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
| BluetoothConnectionStatus | |
| Checks to see if the Bluetooth is connected to a master device | |
BluetoothInit
| BluetoothInit | |
| Startup up Bluetooth communications and assigns a friendly name | |
| Name | |
| Friendly device name | |
| BluetoothReceiveArray | |
| Read an array of bytes from the Bluetooth connection Returns the number of bytes read from the file | |
| Data | |
| Count | |
BluetoothSendArray
| BluetoothSendArray | |
| Send an array of bytes via Bluetooth | |
| Data | |
| Count | |
BluetoothUninit
| BluetoothUninit | |
| Shots down Bluetooth communications | |
ClearDisplay
| ClearDisplay | |
| Clears the display and resets the button count | |
DrawArc
DrawBitmap
DrawButton
DrawEllipse
DrawGraph
DrawLine
| DrawLine | |
| Draws a single pixel thickness line | |
| X1 | |
| Y1 | |
| X2 | |
| Y2 | |
DrawPixel
| DrawPixel | |
| Draws a single pixel in the foreground colour at X,Y | |
| X1 | |
| Y1 | |
DrawQRCode
DrawRectangle
DrawString
FileCreate
| FileCreate | |
| Creates an empty file on the file system | |
| Filename | |
| Text label to draw on the button | |
FileDelete
| FileDelete | |
| Deletes a file from the file system | |
| Filename | |
FileInit
| FileInit | |
| Starts up the FAT file system access function for the SD card 0=OK | |
FileOpen
| FileOpen | |
| Opens a file ready for reading or writing | |
| Filename | |
FileReadArray
| FileReadArray | |
| Read an array of bytes from the current open file Returns the number of bytes read from the file | |
| Data | |
| Count | |
FileWriteArray
| FileWriteArray | |
| Write an array of bytes to the current open file | |
| Data | |
| Count | |
FolderOpen
| FolderOpen | |
| Navigates the current directory to a folder We can use ",," to go up a level or "root" to go back to the root. | |
| Filename | |
GetAPIVersion
| GetAPIVersion | |
GetCardPresent
| GetCardPresent | |
| Checks to see if a SD card is inserted 1=Card Present, 0=No Card Present | |
GetLastButtonPress
| GetLastButtonPress | |
| Gets the button index of the last valid button press. 255 = No new touch detected | |
| GetLastRawTouchCoordinate | |
| Gets the coordinates of the last touch. -1 = no new touch data available. | |
| XY | |
GetSliderValue
| GetSliderValue | |
| Gets the value of one of the slider buttons | |
| ButtonID | |
| the ID of the slider button you want to read | |
ListenForTouch
SetBackgroundColour
| SetBackgroundColour | |
| Sets the background draw colour | |
| R | |
| G | |
| B | |
| SetBacklightBrightness | |
| Sets the brightness of the backlight | |
| Brightness | |
| 0=Off, 255=Max | |
| SetBitmapTransparencyColour | |
| Sets the RGB colour to use as a transparent mask when drawing bitmaps | |
| R | |
| G | |
| B | |
| SetButtonIntervalPeriod | |
| Sets the button repress interval in steps of 10ms | |
| Period | |
| Multiple of 10ms, default 50 = 500ms | |
SetColourPallet
SetFontScaler
| SetFontScaler | |
| XScaler | |
| Width Multiplier Range: 1 to x | |
| YScaler | |
| Height Multiplier Range: 1 to x | |
SetForegroundColour
| SetForegroundColour | |
| Sets the foreground draw colour | |
| R | |
| G | |
| B | |
SetGraphData
SetOrientation
| SetOrientation | |
| Sets the display orientation | |
| Orientation | |
| Range: 0 - 3 | |
SetSliderValue
| SetSliderValue | |
| Sets the value of one of the slider buttons | |
| ButtonID | |
| Value | |
| Range: 0 to 1 | |
UpdateButtonText
| UpdateButtonText | |
| Redraws the selected button with the new text | |
| ButtonIndex | |
| Range: 0 to NumButtons -1 | |
| Text | |
UpdateButtonTheme
| UpdateButtonTheme | |
| Redraws the selected button in a new theme | |
| ButtonIndex | |
| ThemeIndex | |
| Range: 0 to 9 | |
WifiAcceptClose
| WifiAcceptClose | |
| Stops incoming socket requests from being accepted | |
WifiAcceptOpen
| WifiAcceptOpen | |
| Allows incoming socket requests to be accepted | |
WifiConnectToSSID
| WifiConnectToSSID | |
| Connects to a remote WIFI network | |
| SSID | |
| Password | |
WifiDisconnect
| WifiDisconnect | |
| Disconnect from the current socket | |
WifiInit
| WifiInit | |
| Startup up WIFI communications | |
WifiReadIP
| WifiReadIP | |
| Collects the IP address from the WIFI as a string. | |
WifiReceiveArray
| WifiReceiveArray | |
| Read an array of bytes from the WIFI connection Returns the number of bytes read from the file | |
| Data | |
| Count | |
WifiScan
| WifiScan | |
| Scans the WIFI network and returns the number of networks detected | |
WifiScanSSID
| WifiScanSSID | |
| Collects the SSID network name from one of the results of the Scan. | |
| Index | |
| Range: 0 - (Num Returned By WifiSSIDScan) - 1 | |
WifiScanSigStrength
| WifiScanSigStrength | |
| Collects the signal strength from one of the results of the Scan | |
| Index | |
WifiSendArray
| WifiSendArray | |
| Send an array of bytes via WIFI | |
| Data | |
| Count | |
WifiSocketClose
| WifiSocketClose | |
| Close a socket | |
WifiSocketConnect
| WifiSocketConnect | |
| Connect to a remote socket | |
| Address | |
| Port | |
WifiSocketListen
| WifiSocketListen | |
| Listens to a socket for incoming data | |
| Port | |
WifiSocketOpen
| WifiSocketOpen | |
| Opens a socket | |
WifiUninit
| WifiUninit | |
| Shots down Wifi communications | |
Please click here to download the component source project: FC_Comp_Source_CapTouchDIsplay.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CapTouchDIsplay.fcfx
