Component: LED Mono (LED)
| Version | 19.0 |
| Category | LED |
LED Mono component
LED indicator for both embedded and App Developer.
Version information
Library Version, Component Version, Date, Author, Info 18, 1.0, 01-07-25, MW,User Lable Text not changed with Handle. Added Rename event 19, 1.0, 27-08-25, MW, improved functionality, added Hidden option for handle & bug fixes
Here is an example Flowcode program to read the value of a switch and change the state of LED accordingly.
LED Example
SetState
| SetState | |
| Sets the state of the LED, accounting for the polarity. | |
| State | |
| 1=On, 0=Off | |
TurnOff
| TurnOff | |
TurnOn
| TurnOn | |
Please click here to download the component source project: FC_Comp_Source_LED_Mono_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Mono_2dgi.fcfx
