Component: Timer Interrupt (Timing )
Revision as of 21:16, 27 January 2026 by Wiki bot (talk | contribs)
Version 1.1
Category Timing
Timer Interrupt component
The timer interrupt can be set to trigger a specifed User macro evey time a set time has elapsed. Time units that can be selected are: Milliseconds, Seconds, Minutes, Hours or Days Maximum milliseconds = 4294967295 Maximum seconds = 4294967. Maximum minutes = 71582, Maximum hours = 1193, Maximum days = 49 Times can be changed on the fly
Version information
1, 1.0, 06-03-25, MW, Component created
ChangeTimeDays
Fc9-comp-macro.png ChangeTimeDays
Change the interrupt time to a new time in days. Maximum days = 49 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
Fc9-u8-icon.png - BYTE Days
Maximum days = 49
ChangeTimeHours
Fc9-comp-macro.png ChangeTimeHours
Change the interrupt time to a new time in hours. Maximum hours = 1193 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
Fc9-u16-icon.png - UINT Hours
ChangeTimeMilliseconds
Fc9-comp-macro.png ChangeTimeMilliseconds
Change the interrupt time to a new time in milliseconds. Maximum milliseconds = 4294967295 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
Fc9-u32-icon.png - ULONG Milliseconds
ChangeTimeMinutes
Fc9-comp-macro.png ChangeTimeMinutes
Change the interrupt time to a new time in minutes. Maximum minutes = 71582 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
Fc9-u32-icon.png - ULONG Minutes
ChangeTimeSeconds
Fc9-comp-macro.png ChangeTimeSeconds
Change the interrupt time to a new time in seconds. Maximum seconds = 4294967 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
Fc9-u32-icon.png - ULONG Seconds
StartTimer
Fc9-comp-macro.png StartTimer
Start timer interrupt running
StopTimer
Fc9-comp-macro.png StopTimer
Stop the timer interrupt running. Stopping the simulation, also stops the timer interrupt.
Fc9-conn-icon.png Timer Interrupt
Fc9-type-16-icon.png Time Unit
The unit of time to measure
Fc9-type-21-icon.png Time Period
Fc9-type-24-icon.png Call Macro
User macro to be triggered every time the interrupt is triggered.
Please click here to download the component source project: FC_Comp_Source_TimerInterruptPCDev.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerInterruptPCDev.fcsx
