| Author
Matrix TSL
| Version
1.0
| Category
Analog Input
ADC 24bit ADS1220 component
A Precision Low power 24Bit SPI ADC 4 channel device with Programmable Gain Amplifier (PGA) and Data Rates up to 2 kSPS
| Initialize the ADS1220 ADC with default settings
- BYTE
ReadRTDResistance
ReadRTDResistance
| Reads the RTD sensor and returns resistance in ohms
- FLOAT
ReadRTDTemperature
ReadRTDTemperature
| Reads the RTD sensor and returns temperature in degrees Celsius using linear approximation - matches GitHub library get_temperature_from_rtd_ohms_with_linear_approx
- FLOAT
SampleDiffRAW
SampleDiffRAW
| Performs a differential ADC sample between two channels and returns 24-bit raw value. Not all channel combinations are possible, see datasheet p40 section MUX. Returns 0 if the channel selection is invalid.
- BYTE
ChannelA
| Positive channel: 0-3 (AN0-AN3)
- BYTE
ChannelB
| Negative channel: 0-3 (AN0-AN3)
- BYTE
Gain
| PGA Gain: 0=1x, 1=2x, 2=4x, 3=8x, 4=16x, 5=32x, 6=64x, 7=128x
- LONG
SampleDiffVolts
SampleDiffVolts
| Performs a differential ADC sample and returns voltage in volts
- BYTE
ChannelA
- BYTE
ChannelB
- BYTE
Gain
- FLOAT
SampleSglRaw
SampleSglRaw
| Performs a single-ended ADC sample on the selected channel and returns 24-bit raw value
- BYTE
| Range: 0-3 (AN0-AN3)
- BYTE
Gain
- LONG
SampleSglVolts
SampleSglVolts
| Performs a single-ended ADC sample and returns voltage in volts
- BYTE
- BYTE
Gain
- FLOAT
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MOSI Remap Pin
| Select which the target pin to assign the MOSI hardware pin functionality.
MISO
MISO Remap Pin
| Select which the target pin to assign the MISO hardware pin functionality.
CLK
CLK Remap Pin
| Select which the target pin to assign the CLK hardware pin functionality.
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Use Ready Pin
| Use DRDY pin to detect when conversion is complete. If disabled, polling will be used.
DRDY Pin
| Data Ready pin - goes low when conversion is complete
Configuration
Data Rate
| Programmable Data Rate (SPS)
Operating Mode
Conversion Mode
PGA Gain
| Programmable Gain Amplifier (PGA) gain setting
Voltage Reference
| Voltage reference source
Reference Voltage
FIR Filter
IDAC Current (uA)
| IDAC excitation current in microamperes. Typical values: 100, 250, 500, 750, 1000. Default: 250uA
I1MUX
I2MUX
RTD Configuration
RTD Type
| RTD sensor type - determines base resistance at 0°C
RTD Configuration
Reference Resistor
| High precision reference resistor value in ohms. Typically 400Ω for PT100 or 4000Ω for PT1000
Temperature Coefficient
Simulate Comms
| Allows the communications to be simulated overriding the value on the panel slider controls.
Please click here to download the component source project: FC_Comp_Source_External_ADC24Bit_ADS1220.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_External_ADC24Bit_ADS1220.fcfx
