Component: ADC 24bit ADS1220 (Analog Input)
Revision as of 11:01, 25 February 2026 by Wiki bot (talk | contribs)
Category Analog Input
ADC 24bit ADS1220 component
A Precision Low power 24Bit SPI ADC 4 channel device with Programmable Gain Amplifier (PGA) and Data Rates up to 2 kSPS
Fc9-comp-macro.png Initialise
Initialize the ADS1220 ADC with default settings
ReadRTDResistance
Fc9-comp-macro.png ReadRTDResistance
Reads the RTD sensor and returns resistance in ohms
ReadRTDTemperature
Fc9-comp-macro.png ReadRTDTemperature
Reads the RTD sensor and returns temperature in degrees Celsius using linear approximation - matches GitHub library get_temperature_from_rtd_ohms_with_linear_approx
SampleDiffRAW
Fc9-comp-macro.png SampleDiffRAW
Performs a differential ADC sample between two channels and returns 24-bit raw value. Not all channel combinations are possible, see datasheet p40 section MUX. Returns 0 if the channel selection is invalid.
Fc9-u8-icon.png - BYTE ChannelA
Positive channel: 0-3 (AN0-AN3)
Fc9-u8-icon.png - BYTE ChannelB
Negative channel: 0-3 (AN0-AN3)
Fc9-u8-icon.png - BYTE Gain
PGA Gain: 0=1x, 1=2x, 2=4x, 3=8x, 4=16x, 5=32x, 6=64x, 7=128x
SampleDiffVolts
Fc9-comp-macro.png SampleDiffVolts
Performs a differential ADC sample and returns voltage in volts
SampleSglRaw
Fc9-comp-macro.png SampleSglRaw
Performs a single-ended ADC sample on the selected channel and returns 24-bit raw value
Range: 0-3 (AN0-AN3)
SampleSglVolts
Fc9-comp-macro.png SampleSglVolts
Performs a single-ended ADC sample and returns voltage in volts
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-5-icon.png CS / SS
Fc9-type-7-icon.png Use Ready Pin
Use DRDY pin to detect when conversion is complete. If disabled, polling will be used.
Fc9-type-5-icon.png DRDY Pin
Data Ready pin - goes low when conversion is complete
Fc9-conn-icon.png Configuration
Fc9-type-16-icon.png Data Rate
Programmable Data Rate (SPS)
Fc9-type-16-icon.png Operating Mode
Fc9-type-16-icon.png Conversion Mode
Fc9-type-16-icon.png PGA Gain
Programmable Gain Amplifier (PGA) gain setting
Fc9-type-16-icon.png Voltage Reference
Voltage reference source
Fc9-type-15-icon.png Reference Voltage
Fc9-type-16-icon.png FIR Filter
Fc9-type-16-icon.png IDAC Current (uA)
IDAC excitation current in microamperes. Typical values: 100, 250, 500, 750, 1000. Default: 250uA
Fc9-type-16-icon.png I1MUX
Fc9-type-16-icon.png I2MUX
Fc9-conn-icon.png RTD Configuration
Fc9-type-16-icon.png RTD Type
RTD sensor type - determines base resistance at 0°C
Fc9-type-16-icon.png RTD Configuration
Fc9-type-14-icon.png Reference Resistor
High precision reference resistor value in ohms. Typically 400Ω for PT100 or 4000Ω for PT1000
Fc9-type-15-icon.png Temperature Coefficient
Fc9-conn-icon.png Simulation
Allows the communications to be simulated overriding the value on the panel slider controls.
Please click here to download the component source project: FC_Comp_Source_External_ADC24Bit_ADS1220_1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_External_ADC24Bit_ADS1220_1.fcfx
