Component: ST3215 Servo Motor (Mechatronics)
Revision as of 11:01, 25 February 2026 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gray...")
Version 2.0
Category Mechatronics
ST3215 Servo Motor component
Control ST3215 servo motors via serial UART communication using the STS protocol.
ChangeBaudrate
Fc9-comp-macro.png ChangeBaudrate
Change the servo baud rate. Baud rate values: 0=9600, 1=57600, 2=115200, 3=1000000. EEPROM must be unlocked.
Fc9-u8-icon.png - BYTE ServoID
Servo ID
Fc9-u8-icon.png - BYTE Baudrate
Baud rate value: 0=9600, 1=57600, 2=115200, 3=1000000
ChangeID
Fc9-comp-macro.png ChangeID
Change the servo ID. New ID must be 0-253. EEPROM must be unlocked. Note: New ID takes effect after power cycle.
Current servo ID
Fc9-u8-icon.png - BYTE NewID
New servo ID (0-253)
DefineMiddle
Fc9-comp-macro.png DefineMiddle
Define the 2048 position by setting torque to 128.
Servo ID
Fc9-comp-macro.png Initialise
IsMoving
Fc9-comp-macro.png IsMoving
Check if the servo is currently moving. Returns True if moving, False otherwise.
Servo ID
ListServos
Fc9-comp-macro.png ListServos
Scan and return a list of all responsive servos. Returns number of servos found.
Fc9-u8-icon.png - BYTE ServoList
Array to store found servo IDs
Fc9-u8-icon.png - BYTE MaxCount
Max number of servos to try and return. 0=Don't limit
LockEEPROM
Fc9-comp-macro.png LockEEPROM
Lock EEPROM to prevent writes from being saved after power loss. IMPORTANT: Use the NEW servo ID after ChangeID.
Servo ID (use NEW ID after ChangeID)
PingServo
Fc9-comp-macro.png PingServo
Check if a servo is responding. Returns True if successful, False otherwise.
Servo ID to ping (0-253)
ReadAcceleration
Fc9-comp-macro.png ReadAcceleration
Read current acceleration value in steps per second squared.
Servo ID
ReadAngle
Fc9-comp-macro.png ReadAngle
Read current position of servo. Returns position in steps (0-4095).
Servo ID
ReadCorrection
Fc9-comp-macro.png ReadCorrection
Read position correction value in steps.
Servo ID
Fc9-s16-icon.png - INT Return
ReadCurrent
Fc9-comp-macro.png ReadCurrent
Read current in milliamps (6.5mA resolution). Returns current / 6.5.
Servo ID
ReadID
Fc9-comp-macro.png ReadID
Read the servo ID from EEPROM. Returns the stored ID value.
Servo ID to query
ReadLoad
Fc9-comp-macro.png ReadLoad
Read motor load in percentage. Returns load percentage.
Servo ID
ReadMode
Fc9-comp-macro.png ReadMode
Read current operational mode. Returns: 0=position, 1=speed, 2=PWM, 3=step
Servo ID
ReadPosition
Fc9-comp-macro.png ReadPosition
Servo ID
ReadSpeed
Fc9-comp-macro.png ReadSpeed
Read current speed of servo. Returns speed in steps per second.
Servo ID
ReadStatus
Fc9-comp-macro.png ReadStatus
Read servo status flags. Returns status byte with bits: Voltage, Sensor, Temperature, Current, Angle, Overload
Servo ID
ReadTemperature
Fc9-comp-macro.png ReadTemperature
Read temperature in degrees Celsius.
Servo ID
ReadTorqueLimit
Fc9-comp-macro.png ReadTorqueLimit
Read torque limit value (0-1000).
Servo ID
ReadVoltage
Fc9-comp-macro.png ReadVoltage
Read voltage in volts (0.1V resolution). Returns voltage * 10.
Servo ID
Rotate
Fc9-comp-macro.png Rotate
Rotate servo continuously in specified direction. Speed range: 50-1000. Direction: 0=forward, 1=reverse.
Servo ID
Fc9-u16-icon.png - UINT Speed
Rotation speed (50-1000)
Fc9-u8-icon.png - BYTE Direction
SetAcceleration
Fc9-comp-macro.png SetAcceleration
Set servo acceleration in steps per second squared.
Servo ID
Fc9-u8-icon.png - BYTE Acceleration
Acceleration value (0-254)
SetAngle
Fc9-comp-macro.png SetAngle
Move servo to a target angle. Angle range: -180 to 180 degrees.
Servo ID
Fc9-f32-icon.png - FLOAT Angle
SetCorrection
Fc9-comp-macro.png SetCorrection
Set position correction value in steps. Adds correction to position.
Servo ID
Fc9-s16-icon.png - INT Correction
Correction value in steps
SetMode
Fc9-comp-macro.png SetMode
Set operational mode. Mode: 0=position, 1=speed, 2=PWM, 3=step
Servo ID
Fc9-u8-icon.png - BYTE Mode
SetPosition
Fc9-comp-macro.png SetPosition
Move servo to a target position. Position range: -30719 to 30719 steps.
Servo ID
Fc9-u16-icon.png - UINT Position
Target position in steps (0 to 4095)
SetSpeed
Fc9-comp-macro.png SetSpeed
Set servo speed in steps per second.
Servo ID
Speed in steps per second (0-3400)
SetTorqueLimit
Fc9-comp-macro.png SetTorqueLimit
Set torque limit value (0-1000). Controls maximum torque output.
Servo ID
Fc9-u16-icon.png - UINT TorqueLimit
Torque limit value (0-1000)
StartServo
Fc9-comp-macro.png StartServo
Enable torque (start servo).
Servo ID
StopServo
Fc9-comp-macro.png StopServo
Disable torque (stop servo).
Servo ID
UnlockEEPROM
Fc9-comp-macro.png UnlockEEPROM
Unlock EEPROM to allow writes to be saved after power loss.
Servo ID
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Use Flow Control
Fc9-type-16-icon.png Baud Options
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Textual label shown on the component I/O flasher
Selects if the scope traces are automatically added to the data recorder window or not.
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
Simulation data source used to allow the component to connect to various remote devices
Please click here to download the component source project: FC_Comp_Source_ST3215.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ST3215.fcfx
