API FCD.GetPathHandle
Revision as of 14:07, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "class="wikitable" style="width:60%; background-color:#FFFFFF;"" to "class="mtx-class-macrotable wikitable"")
GetPathHandle
Gets a FCD paths handle, suitable for traversal with the Tree API
- STRING PathName
The '.' separated path through the FCD to look in
- HANDLE StartPoint
The handle of an existing FCD path to start the search
- HANDLE Return
This will get a handle suitable for traversal by the Tree API which is a collection of functions suitable for traversing the FCD files.
FCD files are XML files. The PathName must be a list of items, not including the XML root tag of the tags where the XML attributes are located. So to extract a handle to the FLASH memory detailes Pathname="device.memory".
If the StartPoint is provided then it is assumed this is a handle to a previous call to GetPathHandle, and this path is prepended to PathName. So if StartPoint is a handle to "device.configuration" and PathName="settings.setting" then the full path found will be "device.configuration.settings.setting".
  • Add to a calculation icon:
    result = ::FCD.GetPathHandle("pathname", startpoint)
