API File.Buffer.Create
Revision as of 14:11, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
Create
Creates the new file as a circular buffer
- STRING Filename
The name of a new file to create
- ULONG Bytes
The number of bytes to fix the buffer to
- BOOL Write
Set to enable write access
- BOOL Monitor
Set to enable monitoring of the file
- HANDLE Return
  • Add to a calculation icon:
    result = ::File.Buffer.Create("filename", bytes, false, true)
