API Expand.VarName
Revision as of 14:11, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
VarName
Expands a string to the name of a global variable used in the generated code
- STRING Source
The variable name to expand
- HANDLE Owner
A component that owns the variable
- BOOL SizeName
Set true to return the expanded size define
- BOOL FullLine
Set true to expand to a full declaration, else just the name
- STRING Return
This expands a global variable to the name it would be given in the generated code. The size define (the size of the final dimension of the array) may be returned instead if required.
Note this does not return the full expression unless FullLine is true. In this case, Source must be a valid variable name for the Owner component, as the system needs this in order to expand the variable type, array sizes and initialisers.
This is an example of what may be shown with differing SizeName and FullLine values. The sample variable is TestVar, a byte array of 16 elements.
SizeName FullLine Result
false false FCV_TESTVAR
true false FCVsz_TESTVAR
false true MX_UINT8 FCV_TESTVAR[FCVsz_TESTVAR]
true true #define FCVsz_TESTVAR 16
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Expand.VarName("source", owner, false, true)
