API Panel.PCloud.SetPoints
Revision as of 14:11, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
SetPoints
Sets the X,Y,Z point lists
- HANDLE PCloud
The handle to the cloud to set the points of
- FLOAT[] XYZ
The array of (X,Y,Z) coordinates to use
- ULONG Elements
The number of (X,Y,Z) points to set
- NONE Return
Sets the points in the cloud in a chain layout.
Ordering of points in a chain and grid
The points specified will form the points on a line - this is typically the format used for graphs and clouds rendered with Mode_Point. XYZ is an array with index 0 representing X, 1 representing Y, 2 representing Z and 3 representing the next X point (and so on). If the X, Y and Z are in different locations use SetPointsEx. The Elements represents the number ofpoints to display.
  • Add to a calculation icon:
    ::Panel.PCloud.SetPoints(pcloud, _arrayxyz, elements)
