API Component.Property.AddListItem
Revision as of 14:11, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
AddListItem
Alters or appends a list entries text for the property by named index
- HANDLE Handle
The component handle to alter the property of
- STRING Property
The textual name of the property
- STRING Index
The text or integer entry of the property
- STRING Value
The value to update the entry with
- BOOL Return
Sets the text part of a list property identified by its 3-digit Index'. If the line does not exist then a new line is appended to the list.
Note the Index is not the line of the list to extract, but the 3-digit identifier. If multiple lines have the same identifier this will extract the first found.
To find the index from the line, use GetListIndex.
To add the line to the list only if it exists, use SetListItem.
  • Add to a calculation icon:
    result = ::Component.Property.AddListItem(handle, "property", "index", "value")
