Component: J1939 Automotive Node (Comms: System)
Version 1.1
Category Comms: System
J1939 Automotive Node component
Allows an automotive J1939 network node to be created sat on top of CAN bus. Used in heavy duty vehicles it provides a base layer on which 1-16 bit signals or SPN can be assigned and passed between nodes. SPN are arranged into groups called PGN which each contain eight bytes of data.
Please click here to download the component source project: FC_Comp_Source_J1939.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_J1939.fcfx
ClearSPN
ClearSPN
Clears the list of registered SPN allowing new SPN to be registered.
Get_Address
Get_Address
Returns the device (ECU) actual address
Get_Status
Get_Status
Returns the system status. 0 = Ready. 1 = Waiting address claim
Initialise the CAN network and J1939 protocol
- BYTE Preferred_Address
Preferred Address (Requested Address)
Message_Data_Clear
Message_Data_Clear
Clear the CAN Data Buffer
- BYTE DataBuffer
Message_Data_Read_SPN
Read the SPN value from the CAN data buffer
- UINT SPN
- BYTE DataBuffer
Message_Data_Set
Message_Data_Set
Set all data in CAN Data Buffer to given value. e.g. 0 or 0xFF
- BYTE DataBuffer
- BYTE Value
Message_Data_Write_SPN
Write the SPN value to the CAN data buffer
- UINT SPN
- UINT Value
- BYTE DataBuffer
Process
Process
Does the message processing. Call this often.
- UINT TimeElapsed
Time elapsed since last call, in mS. Can be zero for frequent calling.
RegisterSPN
RegisterSPN
Allows a SPN and PGN to be registered onto the system. Returns 1 if the SPN has been regisered successfully.
- UINT SPN
Suspect Parameter Number
- UINT PGN
Parameter Group Number
- BYTE OffsetBytes
Range: 0-7 Data byte where the SPN data starts
- UINT OffsetBits
Range: 0-7 Bit in the data byte where the SPN data starts
- UINT BitLength
Range: 1-16 Number of bits assigned to the SPN data
- BOOL Return
Rx_Message_Check
Rx_Message_Check
If a data message has been received returns the PGN,otherwise 0
Rx_Message_Data
Rx_Message_Data
Returns the DLC and data of the last received message
- BYTE DataBuffer
Rx_Message_Source
Rx_Message_Source
Returns the Source Address of the last received message
Rx_Transfer_Check
Rx_Transfer_Check
Check for incoming multipart data transfers. If received, returns the PGN else 0
- ULONG Return
Rx_Transfer_Data
Rx_Transfer_Data
Returns the byte count and data of the transfer message data
- BYTE DataBuffer
Buffer to receive copied data
- UINT Size
Size (byte count) of buffer
Tx_Message_Send
Tx_Message_Send
Send the prepared CAN message
- UINT PGN
- BYTE DLC
- BYTE DataBuffer
Tx_Transfer_Send
Tx_Transfer_Send
Send a mulitpart data transfer message. Returns number of bytes accepted. Limited by max message size.
- ULONG PGN
Multipart message program number
- BYTE Data
Data buffer to send
- UINT Size
Number of data bytes to send
NAME
Industry Group
Vehicle System Instance
Vehicle System
Function
Function Instance
ECU Instance
Manufacturer Code
Identity Number
Number of SPNs
Number of SPN that can be registered in the database
Transmit Message Buffer Size
Byte buffer size to allocate for transmitted multipart messages. Maximum is 1785 or available RAM
Receive Message Buffer Size
Byte buffer size to allocate for received multipart messages. Maximum is 1785 or available RAM
CAN
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Controller Osc
Bus Rate
Data rate of the bus specified in thousand bits per second, Kbps.
SPI
CHANNEL
SPI Channel selector
MOSI
MISO
CLK
SS
Prescale
Prescale option selector
Sample Point
Data bit read sample point
Config Delay
