Component: Humidity AHT10 (Environmental)
Category Environmental
Humidity AHT10 component
A high precision I2C based temperature and humidity sensor.
Please click here to download the component source project: FC_Comp_Source_Humidity_AHT10.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_AHT10.fcfx
Startup I2C bus and initialise the sensor. Returns 1 if the device is replying to commands.
- BOOL Return
ReadHumidity
ReadHumidity
Gets the humidity reading from the last sample.
- FLOAT Return
ReadTemperature
ReadTemperature
Gets the temperature reading from the last sample.
- FLOAT Return
Sample
Sample
Reads the sensor and collects the latest termperature and humidity readings. Returns 1 for a successful sample.
- BOOL Return
I2C Options
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Baud rate to be used
API
Specifies the API component on the panel to interact with to provide comms simulation.
