Component: Bridge Amplifier (HX711 / BL0122 / BL0132) (Force)
Version 2.0
Category Force
Bridge Amplifier (HX711 / BL0122 / BL0132) component
The HX711 wheatstone bridge amplifier is used to get measurable data out from a resistive bridge. Common examples include load cells, strain gauges or pressure sensors.
A simple example showing how to get a meaningful reading out of the HX711 IC connected to a load cell sensor. Zeros/Tares the reading when the switch is pressed.
HX711 Example
The scale factor was determined by performing calibration with a unity scale of 1.0 and fixed weight weights. A table of weight vs reading was constructed to provide the correct scale factor.
Here is a guide to calibrate your sensor
When 0g was present on the load cell we zero the output.
When 10g was present on the load cell we get a reading of approx 2170.
2170 / 10g = 217 per g.
When 20g was present on the load cell we get a reading of approx 4340.
4340 / 20g = 217 per g.
1 / 217 = Scale Factor of 0.004608
The readings may not be 100% linear so it's best to take several samples based on different weights across the range you want to be able to measure and from this you can work out a close fitting average.
Sets up the I/O ready for communications with the HX711 IC and performs an initial sample to set the channel and gain. Must be called before calling other HX711 component macros.
RawSample
RawSample
Allows the HX711 to be directly read returning the raw unscaled 24-bit reading. Reading is relative to the last defined Zero point. If a timeout occurs and the HX711 is not ready then we return the last valid reading.
- LONG Return
ScaledSample
ScaledSample
Takes a raw sample and then applies the scaling factor to return a real world value.
- FLOAT Return
SetChannelAndGain
SetChannelAndGain
Allows the preselected input channel and gain to be overridden.
- BOOL Channel
Range: 0-1 / 0=A 1=B
- BYTE Gain
Channel A can be 128 or 64, Channel B can be 32
SetSampleCount
SetSampleCount
Specifies the number of samples to perform when taking a reading. The more samples the more filtered the signal will become from high frequency noise.
- BYTE NumSamples
Default 1. Range 1-20
- UINT Delay
Time to wait between samples in milliseconds.
SetScaling
SetScaling
Sets the scaler for the samples to provide a meanningful value. Default scaler is set to 1.0
- FLOAT Scaler
Unity Scale = 1.0
Zero
Zero
Zeros the reading at the current sample
Input Channel
Selects which channel to sample A or B. Gain settings are channel specific. A Gain can be 128x or 64x B Gain is fixed at 32x
Input Gain
Data
Data pin - connected to HX711 Data Out pin.
Clock
Clock pin - connected to HX711 SCK pin.
Clock Transition Delay
Number of microseconds to wait after each clock edge. Max theoretical: 10Hz Mode = 1uS / 80 Hz Mode = 4uS
Wait For Clock Low
Waits for the clock to go low when performing a sample signifying that a new sample is ready to be collected.
Use Median Filter
Please click here to download the component source project: FC_Comp_Source_Load_Cell_HX711.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Load_Cell_HX711.fcfx
