Component: GLCD Textfield (Graphical Library)
Version 1.2
Category Graphical Library
GLCD Textfield component
A component to simplify the process of drawing text to a graphical display. Allows the graphical LCD to be used more like a standard alphanumeric display. Compatible with the Graphical LCDs.
Example program showing how to use the component with a graphical display.
GLCD TextField Example
Clear
Clear
Clears all text from the display
ClearLine
ClearLine
Clears a single line of text from the display
- BYTE Line
Line to clear. Range 0 to CharacterHeight - 1
ClearLineRemainder
ClearLineRemainder
Cursor
Cursor
Moves the current pixel position of the cursor within the coordinate space
- UINT X
Sets the pixel position on the X plane, 0 is the left most pixel
- UINT Y
Sets the pixel position on the Y plane, 0 is the top most pixel
GetCursorPosition
GetCursorPosition
Gets the current pixel position of the cursor within the coordinate space
- BYTE Axis
0=X, 1=Y
PrintASCII
PrintASCII
Prints a single ASCII character to the display
- BYTE Character
Holds an ASCII value e.g. 'A'
PrintFormattedNumber
- ULONG Number
Enter the number or variable to print to the display
- BOOL Format
0 = Signed, 1 = Unsigned
Prints a number to the display as an ASCII string
- INT Number
PrintString
PrintString
Prints a string of ASCII characters to the display
- STRING Text
Enter the text or variable to print to the display
LinkTo
Font
Chooses one of the fonts define dby the display component.
Auto Clear
Automatically clears the remainder of a line when printing data.
Entire Display
Specifies if we are using the entire display or a portion of the display
Orientation 1/3
Swaps the pixel width and height for orientations 1 and 3.
X Coordinate
X coordinate for top left of the text field
Y Coordinate
Y coordinate for top left of the text field
Pixel Width
Pixel width of selected display
Pixel Height
Pixel height of selected display
ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
Please click here to download the component source project: FC_Comp_Source_Lib_GLCD_Textfield.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_GLCD_Textfield.fcfx
FlowcodeHeader was here
