Component: GLCD Bitmap Drawer FAT (Graphical Library)
Version 3.0
Category Graphical Library
GLCD Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
Version information
20, 1.0, 26-07-24, BR, Added pallet buffer allowing 4,8-bit bitmaps to function
Here is an example that will scan for bitmap files in the root of the SD card and display them on a graphical display.
Bitmap Drawer File Demo
The zip file contains the Flowcode project as well as some example bitmap image files taken from Pixabay.
Place the bitmap files on the root of the SD card for the embedded hardware to work.
Display_BMP
Display_BMP
Draws the bitmap image onto the display at the corrdinates X and Y. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
Bitmap file to open from current directory on SD card 8.3 format
- UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
- UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
- BYTE Orientation
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
- BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
- BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Display_BMP_Fast
Display_BMP_Fast
Draws the bitmap image onto the display at the corrdinates X and Y. Speeds up drawing by not assigning X/Y coordinate for each pixel. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
- UINT X
- UINT Y
- BOOL Mode
0=RowByRow, 1=FullWindow(Y Flipped)
- BOOL Orientation
0=Default, 1=Rotated 90 Degrees (only works with Mode 0)
Display_BMP_Fast_Partial
Draws a partial bitmap image onto the display at the coordinates X and Y. Speeds up drawing by not assigning X/Y coordinate for each pixel. Allows drawing a percentage of the bitmap width and height from a specified side (top/bottom, left/right). Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
- UINT X
- UINT Y
- BYTE WidthPercent
Percentage of bitmap width to draw. Range: 0-100
- BYTE HeightPercent
Percentage of bitmap height to draw. Range: 0-100
- BYTE HorizontalSide
Which horizontal side to draw from: 0=Left, 1=Right
- BYTE VerticalSide
Which vertical side to draw from: 0=Top, 1=Bottom
- BOOL Mode
- BOOL Orientation
Display_BMP_Partial
Display_BMP_Partial
Draws a partial bitmap image onto the display at the coordinates X and Y. Allows drawing a percentage of the bitmap width and height from a specified side (top/bottom, left/right). Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
- UINT X
- UINT Y
- BYTE WidthPercent
- BYTE VerticalSide
- BYTE Orientation
- BYTE Transparency
- BYTE Flip
Display_Scaled_BMP
Display_Scaled_BMP
Draws the bitmap image onto the display at the corrdinates X and Y. Scales the bitmap to the specified width and height. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
- UINT X
- UINT Y
- UINT Width
The size in pixels to draw the bitmap image
- UINT Height
- BYTE Orientation
- BYTE Transparency
- BYTE Flip
Display_Scaled_BMP_Fast
Draws the bitmap image onto the display at the corrdinates X and Y. Scales the bitmap to the specified width and height. Speeds up drawing by not assigning X/Y coordinate for each pixel. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING Filename
- UINT X
- UINT Y
- UINT Width
- UINT Height
- BOOL Mode
- BOOL Orientation
GetHeight
GetHeight
Returns the height of the loaded bitmap file in pixels.
- STRING Filename
The filename of the bitmap we want to measure
GetWidth
GetWidth
Returns the width of the loaded bitmap file in pixels.
- STRING Filename
SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
- BYTE R
- BYTE G
- BYTE B
GLCD LinkTo
File LinkTo
ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
Pallet Buffer
Dedicates an area of RAM to be used as a pallet buffer allowing 4-bit and 8-bit bitmaps to be drawn efficiently. No: No additional RAM is used and only 1-bit and 24-bit bitmaps are supported. Yes: 768 additional bytes of RAM are used and 1-bit, 4-bit, 8-bit and 24-bit bitmaps are supported.
Use File Index
Allows multiple files to be accessed at once.
Use File Path
Allows a path to be specified for accessing bitmap files. e.g. Images\
Please click here to download the component source project: FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
